Page 2 of 2 FirstFirst 1 2
Results 16 to 21 of 21
    Apr 2023
    Long island, NY
    Buy a cheap wheel balancer and do it yourself. They work great and are easy to use. If the flywheel is out of balance, the heavy spot will end up on the bottom. Remove a little material from the heavy spot to balance it.
    Amazon.com: JY PERFORMANCE Motorcycle Wheel Balancer, Tire Balancer Stand for Static and Dynamic Tire Alignment, Bike Wheel Balancer for Motorcycles, Road, Sports, MX, and Dirt Bikes Wheels : Automotive
  2. Likes powerabout liked this post
  3. #17
    I live in Prineville Oregon which is in the central part of the state
    The flywheel does not have bearings in the hub so you could not get an accurate reading with this type of balancer. Carter
  4. #18
    Quote Originally Posted by Carter Powell View Post
    The shaft runs on bearings.
  5. #19
    Apr 2023
    Long island, NY
    The shaft rotates on its own bearings on the stand. It stays tight on the flywheel.
  6. #20
    Sep 2014
    Iowa
    I'm thinking of trying the static test stand idea on a couple flywheels I have. I wouldn't trust it if I was a drag racer but I'm guessing the production ones weren't balanced either. I have had a few old aluminum ones lose bits of magnet or start to lose some material on the ring gear. I suspect they would show they are lightly out of balance and I never had any issues with crank wobble or bearing failure. 10k or more I'm sure is a different story.
  7. Likes David - WI liked this post
  8. #21
    Jul 2013
    Carter,
    Just spoke to my local automotive machine shop that balance automative engines.
    They said no problem. Would think a local automotive machine shop that balances car engines by you could do it.
    Dont just static balance it like others are saying. It’s spinning way more rpm than a tire and needs to be dynamically balanced.
  9. Likes VkingMike liked this post
  1. Flywheel balance?
    By tnelsmn in forum Technical Discussion
    Last Post: 02-19-2021, 03:11 PM
  2. who can balance a flywheel ?
    By 985Coonass in forum Technical Discussion
    Last Post: 02-02-2019, 01:06 AM
  3. Flywheel Balance
    By seansbaja1982 in forum Technical Discussion
    Last Post: 09-13-2012, 12:02 AM
  4. 2.4 flywheel balance - neutral?
    By gmacrae in forum Technical Discussion
    Last Post: 08-07-2010, 11:05 AM
