Results 16 to 19 of 19
Yesterday, 10:20 PM #16
Buy a cheap wheel balancer and do it yourself. They work great and are easy to use. If the flywheel is out of balance, the heavy spot will end up on the bottom. Remove a little material from the heavy spot to balance it.
Amazon.com: JY PERFORMANCE Motorcycle Wheel Balancer, Tire Balancer Stand for Static and Dynamic Tire Alignment, Bike Wheel Balancer for Motorcycles, Road, Sports, MX, and Dirt Bikes Wheels : Automotive
powerabout liked this post
Today, 10:40 AM #17
The flywheel does not have bearings in the hub so you could not get an accurate reading with this type of balancer. Carter
Today, 11:32 AM #18
Today, 12:49 PM #19
Flywheel balance?
By tnelsmn in forum Technical DiscussionReplies: 11Last Post: 02-19-2021, 03:11 PM -
who can balance a flywheel ?
By 985Coonass in forum Technical DiscussionReplies: 6Last Post: 02-02-2019, 01:06 AM -
Flywheel Balance
By seansbaja1982 in forum Technical DiscussionReplies: 17Last Post: 09-13-2012, 12:02 AM -
2.4 flywheel balance - neutral?
By gmacrae in forum Technical DiscussionReplies: 16Last Post: 08-07-2010, 11:05 AM
