Results 1 to 15 of 23
    I live in Prineville Oregon which is in the central part of the state
    Who can balance a flywheel for me.
    I need to find someone who can balance a flywheel for me. I am having no luck with this.
    Thanks, Carter Powell
    what engine and flywheel type
    Mercury 2.5 260 16amp. Carter I took it apart to repaint it and did not index the ring gear, bad. Carter
    Jun 2018
    Floating around
    I’m sure you could rig up something pretty easy that would give you static balance. I wouldn’t hesitate to run a static balanced part. Did you reach out to Jay Smith?
    Just talked to him. He doesn't balance anymore. He says on the flywheels he builds they are perfectly balanced. So I am still looking. Help! Carter
    Apr 2023
    Long island, NY
    Try Chris Carson. Not sure he does it but it is worth a try. 305 852 2725. If he doesn't maybe he can point you to someone who can.
    Jan 2020
    Pittsburg, Ca
    Powers does. He will do new magnets and ring gears and re-balance.
    I spoke to them two days ago and they said that they only balance the flywheels that they build! This is starting to get really strange. I wonder why they would tell me that if you know what they can do.
    Carter
    Have you tried any of the regular (4S) engine builders... they all balance car flywheels for like $50: http://dprmachine.com/service-page/
    Feb 2011
    HUDSON, FLORIDA
    i gave up trying, no dice.. something about powers that turns me off. and there close by too.
    Feb 2011
    HUDSON, FLORIDA
    did you take ti completely apart?
  12. #12
    Dec 2010
    current river missouri
    Might try Jeff Dunn. He use to build billet flywheel not sure if he still does but he should be able to balance one for you. He checked one years ago for me.
    https://www.screamandfly.com/showthr...ywheels/page15
  13. Likes David - WI, powerabout liked this post
  14. #13
    Jun 2018
    Floating around
    I believe Dreifort is in your neck of the woods maybe he can or knows someone who will
  15. #14
    I made a shaft at one point with the taper of the flywheel hub turned on it so I could bolt the flywheel on the shaft and had a local electrical motor shop balance them on the machine that they balanced motors that they re-wound with new windings. It worked well, a shop like that may be easier to find than a motor shop that will do it and do it well.
  16. Likes David - WI liked this post
  17. #15
    Still no darn luck! Carter
  1. Flywheel balance?
    By tnelsmn in forum Technical Discussion
    Last Post: 02-19-2021, 03:11 PM
  2. who can balance a flywheel ?
    By 985Coonass in forum Technical Discussion
    Last Post: 02-02-2019, 01:06 AM
  3. Flywheel Balance
    By seansbaja1982 in forum Technical Discussion
    Last Post: 09-13-2012, 12:02 AM
  4. 2.4 flywheel balance - neutral?
    By gmacrae in forum Technical Discussion
    Last Post: 08-07-2010, 11:05 AM
