Results 1 to 4 of 4
    Akron OH
    Drive shaft repair
    Hello,
    Looking for suggestions for a friend on repair of a driveshaft on his 2.5 sportmaster. It's worn/corroded at the pump base. Can these be welded and resurfaced? If so, where would be a good place to send it to? Are there sleeves available and are they reliable? He's trying to decide whether to repair purchase a new one which we all know is a ridiculous price from Mercury. Any feedback would be appreciated.
    Thanks
    Sep 2006
    Key Largo, Fl
    I can cut and re-spline a 3.0 driveshaft to fit your sporty,stainless,Chris
  3. Likes rock, David - WI, sonicss33 liked this post
    charlotte,nc
    Speedi-Sleeve # 99087 has worked great for me. And you can use the standard seal.
    https://www.skf.com/my/products/indu...roductid-99087
    death is certain; life is not
    Oct 2025
    Downingtown, PA
    Quote Originally Posted by nelson edens View Post
    Learned something new today. Thank you! This may come in handy for torn up vertical shafts/motorcycle main shafts on transmissions!
  1. Evinrude Upper Drive Shaft to Lower Drive Shaft Retainer Question
    By mikiedreb in forum Technical Discussion
    Last Post: 08-04-2023, 09:59 AM
  2. Replies: 6
    Last Post: 04-30-2016, 09:53 PM
  3. CLE lower Unit Good case busted input shaft or drive shaft
    By CRLmotorsports in forum Lower Units
    Last Post: 09-25-2014, 06:13 PM
