Results 1 to 15 of 19
    So what exactly do we have here?
    Small block? Does anybody have any info on this?
  2. Thanks fordguy_85 thanked for this post
    Likes 89LASER liked this post
    #2 iron from the Mayo clinic, Fla. / Blue Ridge, VA.
    it's been on here before , not much fanfair at the time , not sure why. obviously if it was without problems it could have taken off , probably alot of " why didn't I think of that ". seem to remember the inventor was an older man , probably deceased by now and will never get credit for his genius . seems like the article showed it running , possibly a video . all I got .
    most overnite successes usually take at least 10 years
    Certified turd polisher,
  4. Likes Instigator, NICE PAIR liked this post
  5. #3
    Cool
    can't quite make out the tag . Virginia
    must run on Moonshine
    Harrel Engineering 6.2 that would be a Big Block . somebody in Va. could run that tag and narrow it down even further.
  7. Likes NICE PAIR liked this post
    Apr 2023
    Long island, NY
    Don't know anything about it. But from the picture I see it's a classic small block Chevy. 4 bolt Valve covers and the distributor by the bell housing. 6.2 would be a 350 with a 400 crank. Probably bored over. Because its set vertical it probably has a dry sump oil setup. I would also think it would have to be fuel injection because how would a float work. Way ahead of its time becauce well 7 Marine. And now we have 300R 400R 500R.
  9. Likes Instigator liked this post
  10. #6
    new mercruser 300 something hp is a big block 6.2
    https://www.greatlakesskipper.com/me...AQBJQOtRX9DzWg
  11. #7
    Apr 2023
    Long island, NY
    Quote Originally Posted by mr fun View Post
    Sorry Fun. Gm's 6.2L is a LS based small block. Not a Big Block. Just has the torque of one
  12. Thanks fordguy_85, mr fun thanked for this post
  13. #8
    Aug 2021
    Osteen/Deltona, FL
    Quote Originally Posted by skialot2 View Post
    Looks to be Fitech or Holley EFI. interesting for sure
    83 Vking 150 Mariner 2.5L
  14. Likes skialot2 liked this post
  15. #9
    Aug 2017
    Philadelphia
    Quote Originally Posted by VkingMike View Post
    Its fairly old so I believe it predates those systems.
  16. Likes NICE PAIR liked this post
  17. #10
    Aug 2017
    Philadelphia
    Makes much more sense in my book as well. I never could understand why the 7 marines had so much complexity. I figured that they'd have to address cooling and oiling anyway to accommodate their high duty cycles so why not go with a simple serviceable configuration with just three spiral bevel gears or better yet a twin spiral bevel setup like a #6 drive.
  18. Likes NICE PAIR liked this post
  19. #11
    Cool
    Ima Driva , dont no nuttin bout no sheenry , but Google says my 383 Chrysler is 6.2 Big block , but just saw a 442 cu in small block at SEMA , Im all confused
  20. #12
    TX......somewhere?
    tha "big block, small block" nomenclature now daze is way different than when we (old guys) were inta hot rod $hit.......... LS combinations changed all that..........
    ta me a big block is a big assed hunk of iron.. a "big block LS" is bored out, stroked small block in anyway shape or form... if its got 4 bolts holdin' tha valve covers on and siamese center exhaust ports itsa small block.... i'm an 'ole guy...........................
    here ya go.. explained in perfect english!!!!!!...................................
    LS big block configurations - Google Search
  21. Thanks mr fun thanked for this post
    Likes sonicss33, skialot2 liked this post
  22. #13
    TX......somewhere?
    jus ta be clear.. here's tha description of tha motors in gregs picture.....
    These are built around highly-developed, marinised versions of General Motors’ fourth generation (Gen-IV) 6.2-litre, small block V8, mounted horizontally, which in automotive guise powers a range of GM vehicles, including the iconic Corvette. For New Zealand readers, versions of this engine are probably best known from Holden Special Vehicles’ (HSV) high-performance models. Sadly, Holden Australia stopped manufacturing cars in 2017.
  23. Thanks NICE PAIR thanked for this post
  24. #14
    Jul 2008
    severn bridge
    that might be worth a try with the LT4 engine, but what's with the wheelie bar,wonder if it's got a tab on the end of it!
  25. #15
    Cool
    to put the elbow shoot for the propwash to blow the bottom clearing the sand and unvieling the shiney Booty laying the on the bottom making you a shipwreck salvor , very common along the Gold coast as the novice weekend warrior class of privateers install them that retract on a small navy of gold hunters. Fun Out
  26. Likes NICE PAIR liked this post
