Results 1 to 12 of 12
    TN
    Bleed line function?
    Can someone please explain how the bleed system works?
    Here is my understanding. The fuel vapor passes through the reeds. At low idle, not all the vapor is taken into the cylinder and collapses in the crankcase. It puddles up and drains down to the check valves. When crankcase pressure increases, it pushes this fuel into the bleed lines which carry it to the cylinders. When crankcase pressure increases, it pushes it to a low pressure cylinder on the downstroke. Is this why it’s critical to have lines connected to the right places? Is this right?
  2. Likes powerabout liked this post
    Mar 2022
    Lake Travis Texas
    If you really want to confuse yourself look at early 3.0 manual with all the check valves. Early 2.4 didn't use check valves and diagrams did not include arrows.Early 3.0 liter charts include arrows and there are enough different versions to make your head spin.
    Yes, generally the fuel moves away from reeds to transfer ports. Yes, it is important hoses are routed correctly.
    Jim
    Mar 2022
    Lake Travis Texas
    Now that my head is circling the drain, There are transfer hoses that are not bleed hoses. I think of the ones the create a vacuum in mains to draw fuel from crankcase and ultimately to front side of reeds or 2.4 carbs. The bottom main gets lubes from crankcase residual fuel and transfers to top bearing.
    Jim
    Apr 2023
    Long island, NY
    On a carb motor, the bleed system takes puddling fuel from the crankcase and pushes it to the boost ports in the cylinder to be burned. On an EFI motor the bleed system takes the puddling fuel and pumps it back into the VST. They also pump Fuel/ oil from the bottom main bearing to the top main bearing to help keep it lubricated.
    I found a description in the manual for an EFI but not a carb motor.
ID:	545492 Click image for larger version.
ID:	545493 Click image for larger version.
    TN
    So am I right for a carb engine?
    Does crankcase vacuum suck fuel to lubricate center mains bearings?
    Mar 2022
    Lake Travis Texas
    Lower left most image shows that. The hose from center mains to intake behind top too carbs
    Jim
  8. Thanks mercrazy thanked for this post
    TN
    Quote Originally Posted by Jim Speros View Post
    But what force pulls it to bearings. Seems there would be negative pressure behind carbs?
    Mar 2022
    Lake Travis Texas
    Negative pressure = vacuum
    Seems to me the fuel mix in crankcase is intermittently under pressure and the vacuum helps move mix thru bearing
    Jim
    Sep 2017
    Ashland city tn
    On a carb motor yes the top and bottom bearings get lubed from the bleed line (unburnt fuel/oil) but I wanna say its by pressure but don't quote me , also I believe if u pull line off and start ur motor u could easily find out
    TN
    Quote Originally Posted by Merc 2.5 View Post
    I did that years ago. At low idle it squirts, if I raise idle over 1200rpm, no squirting. I remember back then, people would let their engine warm up at low idle and it would chug and smoke and foul plugs.
    TX......somewhere?
    Quote Originally Posted by mercrazy View Post
    learned early on ta have tha motor trimmed at least level or a tad positive that helped quite a bit with tha fat idle...
  14. #12
    Plainville, CT
    I've always kind of hated that seemingly silly bleed system and wished there was a simpler alternative. Why does that pooling occur, are the reeds not designed properly or something? Any chance you could do away with it if you use some CCMS reeds?
  1. Fuel Line/Bleed Line Routing for '96 2.5 200EFI
    By Hydrasports205 in forum Technical Discussion
    Last Post: 09-11-2017, 11:08 PM
  2. Yamaha Tech: bleed oil line?
    By screwedbayou in forum Technical Discussion
    Last Post: 07-01-2014, 08:34 AM
  3. bleed line?
    By mercrazy in forum Technical Discussion
    Last Post: 08-26-2012, 05:30 PM
  4. Bleed line ?
    By rusty202 in forum Technical Discussion
    Last Post: 05-17-2005, 09:20 AM
  5. Bleed Line ?
    By BassRunner in forum Technical Discussion
    Last Post: 01-28-2004, 08:44 AM
