Results 1 to 5 of 5
    TN
    Fuse connection?
    Where does the 20 amp fuse above the switchbox plate connect? I’ve looked at drawing but can’t figure out what that symbol is. On the old solenoid trim harness, I left it unhooked and didn’t get power to anything. I hooked it to starter solenoid since I didn’t have a 12 volt source on the coil plate with trim relays. Now everything works.
    Fyi, I found a relay harness and trim works right now…thanks everyone.
    Mar 2022
    Lake Travis Texas
    The fuse connects at starter solenoid
    Jim
    TN
    Quote Originally Posted by Jim Speros View Post
    the other end? I know it goes into harness. Does it go to 8 pin plug then key switch? How does it kill everything. Also there’s a red female pigtail coming out of harness. Does the fuse wire split inside harness?
    Mar 2022
    Lake Travis Texas
    Not sure what your asking. The fuse protects the power in the harness going forward to key switch. It connects to solenoid where primary cable from battery connects.
    Jim
  5. Likes David - WI liked this post
    Apr 2023
    Long island, NY
    On a fishing 2.5 the fuse gets its power from the trim solenoid mounted between the coils. With relays it connects to starter solenoid with the main battery cable. It provides power to the trim switches to activate the solenoids. But it does not provide the main power to the solenoids themselves.
  7. Thanks mercrazy thanked for this post
  1. Fuse help
    By Chingadera in forum Electronics, Audio Systems, and Wiring
    Last Post: 03-19-2021, 08:04 AM
  2. What amp fuse to use???????
    By Georgia Boy in forum Technical Discussion
    Last Post: 07-02-2004, 09:24 PM
  3. Fuse Size?
    By popslavaz in forum Technical Discussion
    Last Post: 10-07-2002, 06:21 PM
