Results 1 to 5 of 5
Thread: Fuse connection?
09-09-2025, 03:51 PM #1
5000 RPM
- TN
- 800
- 98
- 22
- 67
- 78
Fuse connection?
Where does the 20 amp fuse above the switchbox plate connect? I’ve looked at drawing but can’t figure out what that symbol is. On the old solenoid trim harness, I left it unhooked and didn’t get power to anything. I hooked it to starter solenoid since I didn’t have a 12 volt source on the coil plate with trim relays. Now everything works.
Fyi, I found a relay harness and trim works right now…thanks everyone.
09-09-2025, 04:17 PM #2
The fuse connects at starter solenoid
Jim
09-09-2025, 04:22 PM #3
5000 RPM
- TN
- 800
- 98
- 22
- 67
- 78
09-09-2025, 04:33 PM #4
Not sure what your asking. The fuse protects the power in the harness going forward to key switch. It connects to solenoid where primary cable from battery connects.
Jim
David - WI liked this post
09-09-2025, 06:12 PM #5
On a fishing 2.5 the fuse gets its power from the trim solenoid mounted between the coils. With relays it connects to starter solenoid with the main battery cable. It provides power to the trim switches to activate the solenoids. But it does not provide the main power to the solenoids themselves.
mercrazy thanked for this post
Fuse help
By Chingadera in forum Electronics, Audio Systems, and WiringReplies: 1Last Post: 03-19-2021, 08:04 AM -
What amp fuse to use???????
By Georgia Boy in forum Technical DiscussionReplies: 6Last Post: 07-02-2004, 09:24 PM -
Fuse Size?
By popslavaz in forum Technical DiscussionReplies: 1Last Post: 10-07-2002, 06:21 PM
