Results 1 to 5 of 5
Thread: Trim wiring?
    TN
    Trim wiring?
    I’m putting older style trim solenoid system on a 2 wire mid section. Is there a way to make this work? The solenoids are firing but trim doesn’t run. If I ground 1 of the pump wires and hit the switch, the other side runs. How does the 2 wire system work? Do the 2 wire solenoids take the other side to ground? What am doing wrong?
    Apr 2023
    Long island, NY
    Mar 2022
    Lake Travis Texas
    2 wires pumps use relays. The relays have positive and negative contacts in them. 3 wire has a dedicated ground. 2 wire reverses the ground.
    Hey Ski, I can't wrap my head around how the conversion harness works. Have you done that before?
    Jim
  4. Thanks mercrazy thanked for this post
    Apr 2023
    Long island, NY
    Quote Originally Posted by Jim Speros View Post
    Yes. I never bought this harness before. I always used parts i had. But it's not really a conversion. It's really just the correct parts for a 2 wire motor. It just plugs in. It's really very simple. Both relays are negative when off. Both blue and green are ground. When you activate a relay, it switches to positive, completing the circuit. Depending on which relay you activate, blue or green, you get up or down.
  6. Thanks mercrazy thanked for this post
    Sep 2017
    Ashland city tn
    I hear you can make it work but takes 4 solenoids, I didn't wanna bother trying it so I used a harness (customers boat)
  1. OMC Tech: trim wiring help!
    By glastornjet73 in forum Technical Discussion
    Last Post: 10-20-2010, 11:06 AM
  2. trim tab wiring help..
    By louied9 in forum Electronics, Audio Systems, and Wiring
    Last Post: 04-24-2008, 10:33 AM
  3. trim wiring
    By hootie in forum Technical Discussion
    Last Post: 02-18-2005, 12:44 PM
  4. Trim wiring
    By apache21 in forum Technical Discussion
    Last Post: 11-30-2003, 09:59 PM
  5. Trim wiring Q
    By Delta in forum Technical Discussion
    Last Post: 05-24-2001, 11:32 PM
