Results 46 to 52 of 52
Thread: Surface running props
09-04-2025, 08:06 PM #46
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,941
- 595
- 100
- 518
- 627
09-04-2025, 09:34 PM #47
Thanks. Its a little beat up, but not too bad. For $300 I couldn't say no. If I could have picked any pitch, I would have picked a 26 also. I have heard a lot of good things about those TXP OT4 props. Great grip. Can be run excessively high. Specifically made for lightweight fast hulls. And compared to some other props, reasonably priced
09-06-2025, 08:07 PM #48
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,941
- 595
- 100
- 518
- 627
i run the txp on a 15''+ jacked up 4''. have a hull intake.
09-11-2025, 03:48 PM #49
10-03-2025, 08:43 PM #50
I finally fixed my tachometer. Well.... I bought a new one. The old tach read 7000 rpm with my 26P Chopper and 7200 with my 27P Mazco RE4. The new tach reads 6500 with the RE4. Just about perfect for the basically stock 2000 2.5 200 carb I am running. (Boyesen reeds, Bobs tuner, steel bearings and 16A switchbox ignition on premix)
27P - 1.87 ratio - 6500rpm - 75 mph = 16% slip.
That means I should be able to get a couple more mph with a little more tweaking.
KIRCHNER liked this post
10-03-2025, 09:01 PM #51
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,941
- 595
- 100
- 518
- 627
your flying @ 75!
10-03-2025, 10:23 PM #52
Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 7,008
- 680
- 1088
- 1922
- 7966
- 4 Post(s)
I always had better performance numbers out of the DeWald 4 blades but the pro-et was a great wheel as well. If you are going after a top number call Dave DeWald.
Low Friction paint - running surface.
By Down Under in forum Technical DiscussionReplies: 9Last Post: 05-30-2006, 03:29 PM -
Placing Epoxy Resin over aluminum running surface???
By 150aintenuff in forum Fiberglass and Composites DiscussionReplies: 8Last Post: 01-12-2005, 12:09 PM -
sanding running surface
By fullcharge in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 06-20-2004, 12:51 PM -
running surface
By Quick Rick in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 02-17-2004, 12:35 AM -
Running Yamaha props on Mercs
By jrpromax in forum Technical DiscussionReplies: 3Last Post: 01-11-2002, 10:44 PM
