Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 52 of 52
  1. #46
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by skialot2 View Post
    That was before I realized my tach was wrong. This RE4 is a 27P
    thats a nice 27p. i run 26p. so far the txp o/t4 is a winner on my 1200lb skater, drag4 on my 750lb mag-cat.
  2. #47
    Apr 2023
    Long island, NY
    Quote Originally Posted by KIRCHNER View Post
    Thanks. Its a little beat up, but not too bad. For $300 I couldn't say no. If I could have picked any pitch, I would have picked a 26 also. I have heard a lot of good things about those TXP OT4 props. Great grip. Can be run excessively high. Specifically made for lightweight fast hulls. And compared to some other props, reasonably priced
  3. #48
    Feb 2011
    HUDSON, FLORIDA
    i run the txp on a 15''+ jacked up 4''. have a hull intake.
  4. Thanks skialot2 thanked for this post
    Likes skialot2 liked this post
  5. #49
    Apr 2023
    Long island, NY
    Went for a nice ride today with this new to me RE4. Still have some chine walk. But it is a lot less and easier to handle. Boat now does 75mph with a full tank.
  6. Likes VkingMike, KIRCHNER liked this post
  7. #50
    Apr 2023
    Long island, NY
    I finally fixed my tachometer. Well.... I bought a new one. The old tach read 7000 rpm with my 26P Chopper and 7200 with my 27P Mazco RE4. The new tach reads 6500 with the RE4. Just about perfect for the basically stock 2000 2.5 200 carb I am running. (Boyesen reeds, Bobs tuner, steel bearings and 16A switchbox ignition on premix)
    27P - 1.87 ratio - 6500rpm - 75 mph = 16% slip.
    That means I should be able to get a couple more mph with a little more tweaking.
  8. Likes KIRCHNER liked this post
  9. #51
    Feb 2011
    HUDSON, FLORIDA
    your flying @ 75!
  10. Thanks skialot2 thanked for this post
  11. #52
    I always had better performance numbers out of the DeWald 4 blades but the pro-et was a great wheel as well. If you are going after a top number call Dave DeWald.
  1. Low Friction paint - running surface.
    By Down Under in forum Technical Discussion
    Last Post: 05-30-2006, 03:29 PM
  2. Placing Epoxy Resin over aluminum running surface???
    By 150aintenuff in forum Fiberglass and Composites Discussion
    Last Post: 01-12-2005, 12:09 PM
  3. sanding running surface
    By fullcharge in forum Fiberglass and Composites Discussion
    Last Post: 06-20-2004, 12:51 PM
  4. running surface
    By Quick Rick in forum Fiberglass and Composites Discussion
    Last Post: 02-17-2004, 12:35 AM
  5. Running Yamaha props on Mercs
    By jrpromax in forum Technical Discussion
    Last Post: 01-11-2002, 10:44 PM
