Results 1 to 15 of 22
09-06-2025, 03:03 PM #1
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
electric fuel pump recomendations for 200 hp merc carbed
I have a 89 200 hp with wh46's . Have a Carter 4070 in the boat so about a 3 ft head , no return line . It gets 5 psi at idle but when over 300 psi drops to around 3psi and above 4000 the pressure gauge needle is all over moving wildly from just above 0 to just less then 3 psi. When I did a volume test it was putting out about 1/2-3/4 gal per minute. I am thinking I am running out for fuel up top. It will pull about 5500 . same combination would pull 6800 with a non-discript fuel pump , that didn't last long . I am thinking it can't keep up. Should I be looking at a Quick Fuel DFT 125 or Holley Blue ? Should I then run a return line. I am using a AEM regulator
09-06-2025, 03:48 PM #2
5000 RPM
- TN
- 805
- 98
- 67
- 80
Why do you need electric pump?
09-06-2025, 04:10 PM #3
Put the stock pulse pump back on it. It pumps plenty of fuel for that motor. Their is no performance advantage from removing the pulse pump.
mercrazy liked this post
09-06-2025, 04:54 PM #4
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
Front is 1980 225 and the pump is NLA
09-06-2025, 05:00 PM #5
5000 RPM
- TN
- 805
- 98
- 67
- 80
Just put a diaphragm kit in it.
09-06-2025, 06:20 PM #6
Holly red . No regulator should work just fine
coffeeguy thanked for this post
09-07-2025, 03:45 AM #7
09-07-2025, 09:54 AM #8
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Slight thread hi-jack…
I have the exact same motor as the OP: 1990 2.4/200, WH-46s, square style pulse pump. Had it for three years. Rebuilt the pulse pump three years ago when I got the motor simply because I didn’t know its status.
Question: How often should it be pulled apart for inspection and/or rebuild?
-Peter"padded wonder"
__________
the wet:
18’ Bahner bow rider, 2.4/200
the dry:
2003 bmw ///M5
and a handful of clunkers
09-07-2025, 10:48 AM #9
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Duplicate deleted sorry
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
09-07-2025, 02:08 PM #10
5000 RPM
- Sep 2006
- 472
- 166
- 9
- 43
- 51
1980/81 225hp is different and kit is nla
09-07-2025, 02:41 PM #11
5000 RPM
- TN
- 805
- 98
- 67
- 80
If it’s the figure 8 style, there a sierra kit on eBay.
https://www.ebay.com/itm/23359602738...Bk9SR_Cp1tqkZg
09-08-2025, 02:38 PM #12
09-08-2025, 04:33 PM #13
pkstv thanked for this post
09-09-2025, 01:23 AM #14
[QUOTE=skialot2;3454611]Holley red pump has been used for decades without a regulator. The pulse pump pushes higher pressure, I know I had a red pump for years without a regulator.QUOTE=skialot2;3454611]
agree... all i ran on 90% of all carb motors (both production and hi perf.) i've had in my possession for as long as i can remember.. no reg.. no return!... but thats jus me.
09-15-2025, 03:21 PM #15
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Are you saying that you leave the pulse pump in place and just have the Holley red pump from the tank, to the pulse pump?
For now, I'm perfectly happy with my primer buib and pulse pump, but I'd still like to get this squared in my head in case plans change down the road.
__________
the wet:
the dry:
2003 bmw ///M5
Electric Fuel Pumps on Carbed Motors
By Glastron1987 in forum Technical DiscussionReplies: 18Last Post: 06-07-2020, 01:31 PM -
Yamaha Tech: Wiring question adding electric fuel pump to carbed motor
By Mr. Demeanor in forum Technical DiscussionReplies: 8Last Post: 09-15-2013, 08:04 AM -
Electric fuel pump on a 76 merc 1500
By KG4 in forum Technical DiscussionReplies: 9Last Post: 01-12-2006, 11:16 AM -
Two Carbed Motors Off One Electric Fuel Pump??
By Instigator in forum Technical DiscussionReplies: 8Last Post: 03-15-2004, 04:39 PM -
Electric fuel pump for Merc Carbed
By TTriton in forum Technical DiscussionReplies: 13Last Post: 03-31-2002, 09:25 PM
