Results 1 to 15 of 22
    Sep 2006
    electric fuel pump recomendations for 200 hp merc carbed
    I have a 89 200 hp with wh46's . Have a Carter 4070 in the boat so about a 3 ft head , no return line . It gets 5 psi at idle but when over 300 psi drops to around 3psi and above 4000 the pressure gauge needle is all over moving wildly from just above 0 to just less then 3 psi. When I did a volume test it was putting out about 1/2-3/4 gal per minute. I am thinking I am running out for fuel up top. It will pull about 5500 . same combination would pull 6800 with a non-discript fuel pump , that didn't last long . I am thinking it can't keep up. Should I be looking at a Quick Fuel DFT 125 or Holley Blue ? Should I then run a return line. I am using a AEM regulator
    TN
    Why do you need electric pump?
    Apr 2023
    Long island, NY
    Put the stock pulse pump back on it. It pumps plenty of fuel for that motor. Their is no performance advantage from removing the pulse pump.
  4. Likes mercrazy liked this post
    Sep 2006
    Front is 1980 225 and the pump is NLA
    TN
    Just put a diaphragm kit in it.
    Sep 2008
    louisville
    Holly red . No regulator should work just fine
  8. Thanks coffeeguy thanked for this post
    Likes tlwjkw, delawarerick liked this post
    TX......somewhere?
    Quote Originally Posted by skialot2 View Post
    some (like me) are jus plain lazy.......
    May 2009
    7 Post(s)
    Slight thread hi-jack…
    I have the exact same motor as the OP: 1990 2.4/200, WH-46s, square style pulse pump. Had it for three years. Rebuilt the pulse pump three years ago when I got the motor simply because I didn’t know its status.
    Question: How often should it be pulled apart for inspection and/or rebuild?
    -Peter
    "padded wonder"
    __________
    the wet:
    18’ Bahner bow rider, 2.4/200
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    May 2009
    7 Post(s)
    Duplicate deleted sorry
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
    Sep 2006
    1980/81 225hp is different and kit is nla
    TN
    If it’s the figure 8 style, there a sierra kit on eBay.
    https://www.ebay.com/itm/23359602738...Bk9SR_Cp1tqkZg
  14. #12
    Oct 2021
    Bradenton, FL
    Quote Originally Posted by pkstv View Post
    I disagree. the holly without a regulator puts out 7psi, plus you will need a return line to tank otherwise the gas will overheat in the pump
  15. #13
    Apr 2023
    Long island, NY
    Quote Originally Posted by hydra-sports View Post
    Holley red pump has been used for decades without a regulator. The pulse pump pushes higher pressure, I know I had a red pump for years without a regulator.
  16. Thanks pkstv thanked for this post
  17. #14
    TX......somewhere?
    [QUOTE=skialot2;3454611]Holley red pump has been used for decades without a regulator. The pulse pump pushes higher pressure, I know I had a red pump for years without a regulator.QUOTE=skialot2;3454611]
    agree... all i ran on 90% of all carb motors (both production and hi perf.) i've had in my possession for as long as i can remember.. no reg.. no return!... but thats jus me.
  18. Thanks pkstv thanked for this post
    Likes skialot2 liked this post
  19. #15
    May 2009
    7 Post(s)
    Are you saying that you leave the pulse pump in place and just have the Holley red pump from the tank, to the pulse pump?
    For now, I'm perfectly happy with my primer buib and pulse pump, but I'd still like to get this squared in my head in case plans change down the road.
    -Peter
    "padded wonder"
    __________
    the wet:
    the dry:
    2003 bmw ///M5
  1. Electric Fuel Pumps on Carbed Motors
    By Glastron1987 in forum Technical Discussion
    Last Post: 06-07-2020, 01:31 PM
  2. Yamaha Tech: Wiring question adding electric fuel pump to carbed motor
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 09-15-2013, 08:04 AM
  3. Electric fuel pump on a 76 merc 1500
    By KG4 in forum Technical Discussion
    Last Post: 01-12-2006, 11:16 AM
  4. Two Carbed Motors Off One Electric Fuel Pump??
    By Instigator in forum Technical Discussion
    Last Post: 03-15-2004, 04:39 PM
  5. Electric fuel pump for Merc Carbed
    By TTriton in forum Technical Discussion
    Last Post: 03-31-2002, 09:25 PM
