Results 1 to 15 of 16
Thread: Reed stops?
08-29-2025, 05:10 AM #1
5000 RPM
- TN
- 772
- 92
- 19
- 62
- 61
Reed stops?
When putting fiber reeds on 4 petal cages, do I use the stock curved metal stop or is there something better? How far do fiber reeds ever open?
08-29-2025, 06:25 AM #2
Yes. I also suggested blue loctite on the screws. I put a little pool of loctite in a water bottle cap and dipped the tip of the screw in during assembly. Some pics here
https://www.screamandfly.com/showthr...istakes!/page6Hydrostream dreamin
CI STV liked this post
08-29-2025, 11:19 AM #3
It depends on the reeds you are using. Boyeson reeds come with the plate they want you to use with no stops. Chris Carson wants you to use the factory plate with stops.
08-29-2025, 12:08 PM #4
5000 RPM
- TN
- 772
- 92
- 19
- 62
- 61
Tony doukas reeds
08-29-2025, 10:11 PM #5
Just use hold downs
08-30-2025, 05:30 AM #6
TDR reeds here using factory stops. Runs great. Although I have to wonder here if this is my choke point? Maybe if I pull the stops it makes more power? Hmmm
08-30-2025, 06:13 AM #7
5000 RPM
- TN
- 772
- 92
- 19
- 62
- 61
I can’t get an answer as to how far the reed opens without stops during normal operation. I would guess not much more than the reed stop allows? Seems the stops might prevent damage due to lean sneeze, backfire, etc.?
08-30-2025, 06:19 AM #8
5000 RPM
- TN
- 772
- 92
- 19
- 62
- 61
08-30-2025, 08:54 AM #9
I highly doubt that reeds open all the way to the stops. I have never seen a mark on any reed indicating they ever hit the stops.
08-30-2025, 11:01 AM #10
08-30-2025, 12:41 PM #11
5000 RPM
- TN
- 772
- 92
- 19
- 62
- 61
08-30-2025, 01:24 PM #12
mercrazy thanked for this post
08-30-2025, 05:29 PM #13
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,877
- 561
- 93
- 500
- 598
sounds good on, another 1-2 hrs left for me on breakin. had it to 4000=50mph. hull weight 750lbs. running a scorpion26p. motor has no reed stops?? bought it that way? going with a 5hr breakin period. metal bearings,wsm 1.5mm 16a system o20over.
08-30-2025, 06:49 PM #14
08-30-2025, 08:42 PM #15
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,877
- 561
- 93
- 500
- 598
i put the boat/mtr/trailer on scale, tanks empty,lipo batt=0. subtracted 400 lbs/motor +trailer. 750lbs just what mfg. said from an old brochure, not exact, but close. heavy for only 15'6''x7'beam. front deck is 3/16'' thick, all f. cloth w/ 1''x2'' cross braces 16'' o/c from dash to bow.
OMC Tech: Reed stops
By keefallan in forum Technical DiscussionReplies: 13Last Post: 12-01-2020, 05:33 PM -
Use reed stops with carbon reed ???
By merc_racer in forum Technical DiscussionReplies: 5Last Post: 10-21-2012, 11:01 AM -
Yamaha Tech: Chris Carson....Reed stops vs. no reed stops.
By Mr. Demeanor in forum Technical DiscussionReplies: 2Last Post: 09-11-2012, 09:22 PM -
reed stops?
By gambler183gt in forum Technical DiscussionReplies: 4Last Post: 01-05-2004, 11:13 PM -
Reed stops
By bw1969 in forum Technical DiscussionReplies: 3Last Post: 06-23-2002, 08:52 PM
