Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 76
  1. #46
    May 2019
    Georgia
    Some of youse guys can't read, or maybe just ignore the OP's question. He said UNDER 20'. A 20 footer isn't UNDER 20'.
  2. Thanks Greg G thanked for this post
  3. #47
    He said 19 ish footer. No exact dimensions were given. How about a NINETEEN foot Action Marine? Nice boat that could handle a 15'' mid. They vary by model from 19'10'' to a 19'5''. Close enough?
    May 2009
    7 Post(s)
    Quote Originally Posted by CUDA View Post
    The Venom was /is a great design, with It's easy to drive no surprises Pad design.
    Unlike the death defying Allison
    This is the first I'd heard of Allisons being hard to drive fast.
    -Peter
    "padded wonder"
    __________
    the wet:
    18’ Bahner bow rider, 2.4/200
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
  5. #49
    PARADISE /Naples
    TOO FUNNY...
    You're stuck down under
    2 months ago a friend was very lucky, when It hooked he ended up on shore going past pine trees and Palmetto's
    He was bloody, but not broken.
    I saw Glenn Reynolds take out a 1/4 master in a 1/4 mile race, guy got cut up BAD.
    That's why their nick name is "HOOKERS"
    If you back out too fast the bow drops and since there is no bend in the keel design the front part of the keel drops and to the right you go.
    I guess you know nothing about Allison's
  6. #50
    I always thought the "pencil roll" making too much lift was the hooker part. Lift the stern and they swap ends.
  7. Likes hellbents-10 liked this post
  8. #51
    Lake Coochiching, Ontario
    I just figured any V bottom will hook if you push it too far. Allisons are faster than most and get pushed farther.
  9. Likes RiverRat71 liked this post
  10. #52
    Sep 2014
    Iowa
    The old venoms you are just hoping to get back to the ramp in anything less than 3 delaminated pieces
  11. #53
    PARADISE /Naples
    Must have added wax to the resin between layers,
    Seriously fiberglass work is quite simple, I don't understand how they had such problems,
    Use Ashland Vinyl Ester, get the air out, simple
    I used 2 layers of mat 2 and two of 1708, and I was told that was overkill
    Wally Lamkin said he used mat and 2 of 1208
    How did they mess up so bad ?
  12. #54
    PARADISE /Naples
    Quote Originally Posted by David View Post
    No sir it is the straight Keel, Wally Lamkin got sued by Allison early on for splashing,
    Triad 21, Wally won, he said he also changed the keel area a little, so his design (improvement) never hooked
    Wally was the one who understood the reason for the hook, Wally said, just a little change in the keel area is all that's need to make them
    safer. Wally was a great Talented man, He's the only one that did West Coast Gel in the mold on the east coast.
    https://www.facebook.com/groups/1389632714608406/
  13. #55
    PARADISE /Naples
    You would be surprised how much effect that little lip makes,
    My design was 11.5 inches flat, like the Triad DR20, neither boat ever hooked,
    Almost drives like a real tunnel hull, the side sponsons on the DR20 and the Cuda prevented any spin outs
    But I had the lip / roll along the sides not the back like Allison's
    The first time I did a small lip all the way to the rear,
    I ended up sanding off the last 2.5 inches because that little bitty lip prevented the bow from rising,
    I was amazed how much force was created by that little side lip,
    I have 2 very different hull molds, one deck.
    Attached Thumbnails Attached Thumbnails 06272006 boat mold 001.jpg   Image005.jpg   dsc00020.jpg   dsc00022.jpg   dsc00003.jpg
  14. Likes Jimboat liked this post
  15. #56
    I really liked your Cuda boat and the old screaming johnrude it had. Ran out good the day we were up river. You should come up more often, lot of guys running some real nice boats. Lotta fun...
    Oct 2018
    Flint River GA
    I think any v will hook when flyin the piss out of em. Allisons can be worse because of the keel design. That design also is the reason they do better in the snot than a lot of other boats their size & weight. Aways a trade off. You just have to be really careful & patient when trying for big numbers in the Alli. You'll need some luck on race day to beat one. RR
  17. Likes mikesufka liked this post
  18. #58
    PARADISE /Naples
    Quote Originally Posted by AlliStan View Post
    For your Information, any boat under 20 feet has to abide by USCG regulations, we are talking about having proper flotation, front and rear to keep it afloat, over 20 ft you don't, also You have Max HP, which is nothing more than a math calculation, has nothing to do with design or structure of boat,
    So a 19 ft boat that is 7 ft wide gives 266 HP max a 20 ft 7 wide gives you 280 hp max
    Over 20ft no stupid rule,
    He want's to install 300r , Insurance and USCG prevents
  19. #59
    PARADISE /Naples
    I'll be out soon, painting # 1 boat the red one, white AWL grip, It will have a fresh 300XS 15 inch, An old friend Brent wants to try a top speed run, he has top end props and the need to reach top speed, I have never set up a boat up for top a speed run, I've been 115mph a bunch, but after flipping my 400 lb Sleekcraft in 1985, I have NO urge to get wet again.
  20. #60
    Jun 2018
    Floating around
    I hooked my Vking first time out with the lwp last year. Jacked too high. Prop is an ars lifter. Corner too fast around 70 going in. Went rubbery faster than I had a feel for. Blew out and the ass end started to wrap around the front. About halfway through this rapid motion it became a frisbee and went airborne and seemed to just kinda fly sideways until it landed with a resounding thud completing the 160 or so degree turn. Took on a bunch of water but otherwise all good. After that I started to granny speed those turns. Got the jackplate trick figured out now. It’s back to hammer down
  21. Likes Dain liked this post
  1. Fastest single engine V bottom boats
    By dream4ta in forum General Boating Discussion
    Last Post: 03-13-2022, 08:26 PM
  2. Fastest single engine V bottom, outboard or inboard
    By David in forum General Boating Discussion
    Last Post: 11-13-2020, 02:55 PM
  3. Single engine V bottom..what's your slip?
    By Boat211 in forum Props, Setup, and Rigging
    Last Post: 01-28-2014, 09:22 PM
  4. Fastest Single Outboard Powered V Bottom?
    By fgbiv in forum General Boating Discussion
    Last Post: 12-25-2004, 09:42 PM
