Results 1 to 8 of 8
Thread: 2006 300xs
    Jul 2011
    Gloucester, VA
    2006 300xs
    Selling my 300xs has about 100 hours on a rebuild. The ECU was replaced 71 Hours ago because it lost the fuel pump driver. it has the 6200 RPM ecu.
    Compression is 125 on all 6. Motor was originally 25" with a offshore mount, and pump but right now its 20" with a standard clamp. The coned case on it doesn't have the best install job but I have another 20" lower that will go with it.
    Located in Mathews VA. I can crate and ship.
    Asking 10,000 for the motor, offshore clamp and pump, and spare 20" case. Text is best for me as Im not on here much anymore. 8o4-5one2-84four1.
ID:	543892Click image for larger version.
ID:	543893Click image for larger version.
ID:	543894Click image for larger version.
ID:	543895Click image for larger version.
    Feb 2011
    HUDSON, FLORIDA
    is that motor 520 lbs MOL? 40LBS more than a 2.5?
    Jul 2011
    Gloucester, VA
    Believe it's closer 2 500
    May 2007
    Lutcher, La
    Do you still have the 25" lower?
    Feb 2011
    HUDSON, FLORIDA
    will i need a special control/ harness for it? i have pre opti merc plug/controls, no digital stuff... does the 20 power trim working?
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by KIRCHNER View Post
    Sorry just saw this. I dont get on here much anymore. You can get an adaptor to use your harness. Yes the power trim works. I'll try and remember to check back on here but messaging me at the number in the 1st post is best. I'll shoot it to you in a PM also.
    Feb 2011
    HUDSON, FLORIDA
    do u still have the motor?
    Jul 2011
    Gloucester, VA
    Sorry have not been on here. Yes I do.
  1. 2006 Mercury 300xs 3.2 Stroker
    By Rick W in forum Outboard Engines
    Last Post: 09-28-2023, 02:59 AM
  2. 2006 Tuff 21 with 300xs
    By topgun marine in forum Hulls larger than 20'
    Last Post: 03-21-2015, 11:04 AM
  3. Mercury Tech: 2006 300xs question
    By TTriton in forum Technical Discussion
    Last Post: 03-01-2009, 10:10 AM
