Results 1 to 15 of 39
Thread: Outboard motor setback bracket
04-01-2025, 09:14 AM #1
Hi,
Did some research on the forum and haven't found something on this.
I was wondering what type/brand of setback brackets you guys are running?
I currently have an 12" setback bracket. The problem is it's made of painted steel so it's heavy and since I switched from a 260 to a SHO it's a big anvil now and I'm looking to safe weight. My steel brackets (side brackets) has been lightened with some pockets in it an of course the mounting plate (where the jack bolts) is aluminium (3/4) but I still think there could be some weight saving there.
Again I've done some research for brackets like Bob's, etc but I don't seem to find angled one, the back of the Cougar is straitgh so I need a bracket with negative trim built in.
Thanks in advance for your help and inputs.21 Cougar & 2.5 260 (till 2024)
21 Cougar & Vmax SHO (Now)
04-01-2025, 11:52 PM #2
Supporting Member
- Jul 2013
- California
- 1,703
- 27
- 84
- 116
- 377
Try:
Hydro Dynamics
http://www.hydrodynamics-usa.com/
They use to make fixed brackets with different transom angles. Don’t know if they still do.
How old is your Cougar? Never saw them with a steel transom bracket.
jimmybrie thanked for this post
04-02-2025, 12:34 AM #3
Maybe you could use these with a standard bracket.
Reversible Transom Wedges 10 degree - Bob's Machine
04-02-2025, 04:08 AM #4
Junior Member
- Oct 2023
- Jensen Beach FL
- 24
- 7
04-02-2025, 10:37 AM #5
Alright thanks for the link, don't see any brackets thought.
It's a 1986, don't know if this is the original bracket. I know this was originally a twin motor bracket that was modified to make a single one by my father when he bought the boat about 25-30y ago. It ran twin 200 before my father got it. I kept the boat when he passed away. So much memories with it.21 Cougar & 2.5 260 (till 2024)
04-02-2025, 10:41 AM #6
04-02-2025, 10:57 AM #7
Use angled washers: https://www.vancemfg.com/vance-angle...ransom-wedges/
04-02-2025, 11:11 AM #8
Supporting Member
- Jul 2013
- California
- 1,703
- 27
- 84
- 116
- 377
04-02-2025, 11:20 AM #9
Humm with a beer on the side looks even better! Bolted like this I could pretty easily fabricate one, I'm equipped to weld but bolted would be safer imo. What thickness looks like the plate are 1/2" but is it 3/8" angles? I also like the angles on both sides on the transom. Mine is only towards the interior with 8 bolts 4 on each side... How was the transom (condition, straight or warped) when you did your hull rebuild? Also that way you can easely play with the set back by changing only the side plates.
I'm doing my cone,lwp and fatshaft right now. when I'm done I will take a look at that possibility.
Thank youLast edited by jimmybrie; 04-02-2025 at 11:34 AM.
04-02-2025, 11:20 AM #10
Supporting Member
- Jul 2013
- California
- 1,703
- 27
- 84
- 116
- 377
The problem with using a standard jack plate/ transom bracket and angle blocks is that it angles the jackplate downward. This creates a big scoop and sets everything lower which gives you less lift capability in the Jack relative to the bottom of the boat.
It really needs to be built custom due to the transom being vertical.
Another one to try is STR in Florida. https://shauntorrenteracing.com/
Does really nice custom CNC machined stuff. Pricey
04-02-2025, 11:21 AM #11
04-02-2025, 11:44 AM #12
That is what these are for.
Wedge Washers - Bob's Machine
04-02-2025, 12:35 PM #13
I see, makes sense thank you
04-02-2025, 12:48 PM #14
04-02-2025, 01:17 PM #15
A bracket like billy bilt has would be best. Especially if you could get it with the hydraulics built in instead of a second bracket.
Stainless Marine 6" Outboard Setback Bracket $225
By starviper10 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 08-05-2025, 04:34 AM -
Donzi 22 Outboard Conversion – Setback & Bracket Advice Needed
By Malcomdesvaux in forum Technical DiscussionReplies: 5Last Post: 02-28-2025, 05:55 PM -
Engine on bracket. Raising motor w/o more setback + more questions.
By Mr. Demeanor in forum Props, Setup, and RiggingReplies: 51Last Post: 07-18-2006, 09:05 AM
