Results 1 to 15 of 18
    Nov 2023
    Princeton New Jersey
    New Kilo Hydroplane
    We (http://princetonelectricspeedboating.com) just received our Black Sheep Racing (BSR) hydroplane and are working to rig it with our custom 5.5" outboard frame and the electric powertrain before it goes back down to BSR to get the carbon decks installed.
    The new boat will make 300+ hp and should weight <1200 lbs with the driver. We are excited to raise the electric kilo record far above the 114.20 mph number we set at the end of 2023!!
    Here are some pictures of the hull on our custom CTS Trailer tilt trailer. Enjoy!
ID:	540330Click image for larger version.
ID:	540331Click image for larger version.
  2. Thanks Instigator thanked for this post
    Lake Coochiching, Ontario
    Is the hull design for oval racing or specifically for top end. Good luck.
  4. Likes Jimboat liked this post
  5. #3
    Nov 2023
    Hey David, Thanks! It's built specifically for top end. The cockpit is centered in the boat and the sponsons/tunnel shape is designed to be best in a straight line. It will still run well on an oval but best for a kilo
    Pekin, IL
    Good luck in your venture. Boat looks extremely cool.
    Rock
    Team Junk
    SOCAL, the land of 75* and sunny!
    Cool project, best of luck at breaking the record. Who's electronics do you use? It would be great to hear more aboot this rocket ship.
    Nov 2023
    Thanks Rock, we are really happy with how it is shaping up. It'll certainly be different from most everything currently out there.
    Nov 2023
    Thanks John. For the data logging and power distribution we are using an AiM PDM and digital display. The high voltage battery pack is custom built by Danecca limited out of the UK. The motor controller is the Scott Drive SD500 from New Zealand. Lastly the electric motor is from Flux Marine.
    Battery: ~450 lbs, 712 volts nominal, capable of 300+ hp
    Motor controller: 35 lbs
    Motor: 65 lbs, peak power 7500-10,000 rpm
    Here is a photo of the battery pack and the CAD for the dash.
ID:	540359 Click image for larger version.
  10. Likes Mugs914, 89LASER, NICE PAIR liked this post
    Nov 2023
    One step closer to an outboard hydro with a rudder! About to join a small group of boats
ID:	540558Click image for larger version.
  12. Likes David - WI, Mugs914, NICE PAIR liked this post
  13. #9
    Nov 2023
    Mock up of the rear cowling that go from the back of the cockpit and fully enclose the outboard motor. With the electric motor being so small combined with our short midsection we can get very creative with the design of the cowling. Looking to optimize the aero of the boat as much as possible. Working on making the mold now and should have the finished carbon cowling in a couple of weeks. More to come soon.
ID:	542495Click image for larger version.
  14. Likes NICE PAIR liked this post
  15. #10
    PARADISE /Naples
    So, how fast due you predict?
  16. #11
    Nov 2023
    Quote Originally Posted by CUDA View Post
    The current boat ran 121 mph making 182 hp and was not maxed out when we snapped the prop shaft at the record event in Oct of 2023. Target for this boat is 150 mph. The electric powertrain is designed to make 300+ hp. Time will tell this summer as we begin testing and tuning. We just ordered some big pitch Dewald wheels for the SSM4 gear case and we are very excited to see how they compare to existing SSM4 kilo props.
  17. Likes NICE PAIR, Instigator liked this post
  18. #12
    Pekin, IL
    Hope you make it.
    Rock
    Team Junk
  19. #13
    45 Post(s)
    Number 6 SSM
    Quote Originally Posted by PUSpeedboating View Post
    Is that a Merc #6 SSM?
  20. #14
    Nov 2023
    Quote Originally Posted by rock View Post
    Hope you make it.
    Rock
    Thank you! I hope we do too
  21. #15
    Nov 2023
    Quote Originally Posted by WaterZebra View Post
    No this is a Merc #4 SSM. Power level is closer to what the #4 is built for and more parts and support available.
  1. Popeyes kilo cat
    By D.E. in forum General Boating Discussion
    Last Post: 03-02-2020, 03:05 AM
  2. Kilo question
    By 2us70 in forum Outboard and Racing History
    Last Post: 05-28-2013, 11:44 AM
  3. Kilo anywhere??
    By Wayne Worthy in forum General Boating Discussion
    Last Post: 05-17-2009, 08:39 AM
  4. kilo runs
    By afr in forum General Boating Discussion
    Last Post: 01-04-2008, 09:58 PM
  5. Old kilo record run...
    By Russ in forum General Boating Discussion
    Last Post: 09-13-2003, 03:31 PM
