Results 31 to 45 of 47
  1. #31
    Miami,Fl
    Could you show some more pictures how you mounted that where you connected the ends I have been trying to use an actuator I have on a 1978 55hp johnson. Thanks Rick
  2. #32
    Sep 2022
    Portland, OR
    Quote Originally Posted by delawarerick;[URL="tel:3437744"
    3437744[/URL]]Could you show some more pictures how you mounted that where you connected the ends I have been trying to use an actuator I have on a 1978 55hp johnson. Thanks Rick
    here are a couple. The top one is just a stainless exhaust clamp and some aluminum angle brackets.
    Attached Thumbnails Attached Thumbnails 2ED763DD-6DC9-4FFE-95DA-6C48C2E76F8E.jpeg   161D8358-5992-46F9-BA91-F1C93AD2DF51.jpeg
  3. Thanks delawarerick thanked for this post
    Likes Instigator, 89LASER liked this post
  4. #33
    12 Post(s)
    Genius, love it!
    Quote Originally Posted by Spaceman Spiff View Post
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  5. #34
    Sep 2022
    Portland, OR
    Genius, love it!
    Thanks. I got the idea from some of the people on the forum at dillon-racing.com
  6. Likes Instigator liked this post
  7. #35
    Sep 2022
    Portland, OR
    So I'm kinda stuck at 48mph. I get the onset of porpoising at that speed. Bob Dillon suggested I try to trim out to get past it, but I'm pretty sure I don't have enough trim left to do that. I tried a whale tail and sitting further forward about 8" and those had zero effect. I can't move any more weight around. What else can I try? Raising or lowering the motor, or adding cup to the prop? If I raise it with this prop, it will induce slip. I bought Jim's Tunnel Hull book, but I have no idea where it is.
  8. #36
    Ontario, Canada
  9. Thanks Spaceman Spiff thanked for this post
  10. #37
    Sep 2022
    Portland, OR
    Quote Originally Posted by Jimboat View Post
    Here's an article on Porpoising that may help.
    Thank you so much! Just what I needed. I also found my book, buried in the garage.
  11. Likes Jimboat liked this post
  12. #38
    Sep 2022
    Portland, OR
    With my 1/8 of a ton body weight, I wonder if I should be moving the weight back toward the stern?
  13. #39
    Sep 2022
    Portland, OR
    I put a couple of sand bags (maybe 60lbs total) right at the transom and that changed the angle of attack dramatically. Tied up to the dock, the rear of the deck was even with the surface of the water. I was able to get up to at least 46 without even trimming it out at all. 39 was about all I could do before at full negative trim. It was really choppy out there with a 15mph wind so I couldn't get too squirrely with it because I was close to stuffing a couple times. But, it seemed to like the shift in weight to the back. Can't wait to get back out there early in the morning when the water is usually glass.
  14. Likes OnPad liked this post
  15. #40
    Sep 2022
    Portland, OR
    Well, I got cleaner water today and got about same the results. I even raised my engine up 1/2". It still hits the hump zone about 46mph. The hydrodynamic stability starts to fade at that speed. The rear seems a little "loose". I set my tachometer to 12 poles and that seemed to make it tell the truth. I'm running about 5200rpm at 46mph with the 21P prop. I still can't get myself to trim it out beyond 48mph. I think I need to find a short shaft motor before I can really start to trust the rear.
    Would adding cup to the prop help it hold up the bow better, possibly moving the hump zone to a higher speed?
  16. #41
    PARADISE /Naples
    You have a lot of weight forward, be interesting if you could move back in the boat a foot or two, find a 120lb person in there and see how boat reacts .
  17. Thanks Spaceman Spiff thanked for this post
  18. #42
    sw florida
    my underpowered 16' Seebold tunnel handles a lot better and runs a lot better now with the CG forward.
    I rested it on a 8x8 to figure where the cg was. Im at 35% from the trailing edge of sponson.
    Only runs in the mid 70's so certainly not "flying" but will do better when I put some better power on it
    after the "car" is ready for the car shows again.
    Your boat is super cool.!! i will build one soon.
    I have all the plans.
    Dago.
  19. Thanks Spaceman Spiff thanked for this post
  20. #43
    Sep 2022
    Portland, OR
    Quote Originally Posted by dagodiver View Post
    Dago.
    Thanks, and good luck with your build.
    It's interesting though, I've tried moving the weight forward and back now and the hump zone still starts at 46mph.
  21. #44
    PARADISE /Naples
    At 260 lbs he has plenty of weight forward
    Attached Thumbnails Attached Thumbnails !cid_196F89FDA7804BE0A0B065EE69CC4C96@gowanda.jpg
  22. #45
    sw florida
    Have you found the CG of the hull with you in it.?
    Then the fuel should go on top of that point when you find what works.
    So as you burn fuel the CG stays the same you just get lighter.
    Dago
  1. Dillon-Racing Laker 14' Build
    By lwilde.0422 in forum Props, Setup, and Rigging
    Last Post: 04-18-2025, 07:20 PM
  2. what would be a good engine for a 14ft laker tunnel
    By boatermike in forum Racer's Hangout
    Last Post: 08-02-2016, 10:25 PM
  3. Hey Thumper, Laker, Laker's wife, and Sgt. Laker
    By Ron V in forum The Scream And Fly Lounge
    Last Post: 08-11-2005, 10:46 AM
  4. Laker
    By SGT LAKER in forum The Scream And Fly Lounge
    Last Post: 06-02-2004, 07:18 PM
  5. Hey Laker
    By Barefoot Bob in forum General Boating Discussion
    Last Post: 10-24-2002, 10:47 PM
