    Feb 2008
    Mike Butler
    Top contributor
    Bob Degriener, Harold Nauss, Terry and Nancy Leatherby.
  2. #12602
    Feb 2008
    Mike Butler
    Top contributor
    Mike Wallace.
    (#77 Schulze/Evinrude Starflight SS)
  3. Thanks Bob V thanked for this post
    Likes Bob V, Watermark liked this post
  4. #12603
    Feb 2008
    Jack Aylsworth
    Group expert - Top contributor
    1968 – THE BEGINNING OF OMC’s LEGENDARY LOOPERS
    Billed as America’s first looped charged, multi-cylinder outboards - and the most potent motors in the mid-horsepower range - OMC’s revolutionary loopers produced more power per-cubic-inch with less fuel consumption. Over a 33-year period, the 2 & 3-cylinder loopers became two of OMC’s longest running and most profitable models.
    A Wide Range of Models – From Pleasure Boats, to Racing, to Military, to Commercial - The 55hp 3-cylinder was launched in 1968. In 1971, a 2-cylinder, 50hp looper joined the 3-cylinder looper which had increased to 60hp in 1970. Continuing power increases for the 3-cylinder model followed with 65hp in 1972, then 70 hp in 1974. Also in 1974, both brands targeted performance boating with specially styled and named loopers – the 70hp Evinrude Hustler and Johnson Stinger. (The Stinger is best remembered for its striking orange paint job.) Evinrude extended their performance offerings with a 2-cylinder 50hp Sizzler. Looped horsepower jumped again in 1976 when Evinrude introduced the 75-S and 55-S Sport models and Johnson debuted the 75hp Stinger and a 55hp 2-cylinder. While the 3-cylinder motors peaked at 75hp, the 2-cylinder line-up would expand to 50, 55 & 60 horsepower models by 1980. (See the ads for additional tech info.)
    THE “RED HOT” STINGER– Launched as a “1972 Limited Edition” model - just in case screaming orange was too daring - the 65hp Stinger was an instant hit. The 1972 / 1973 model, shared identical mechanicals with the standard 49.7 cu. in. Johnson 65 looper producing its BIA certified horsepower at 5000 rpm.
    Playing off that initial success, an upgraded 70hp Stinger followed in 1974 with a massive ‘70’ on its flanks. Its additional 5 horses were credited to refined tuning and improved carburetion. Doubling down on performance, horsepower increased again in 1975, now to 75. Again, festooned with a bold horsepower ID on its sides announcing its presence. Those extra 5 horses came from new exhaust ports, a redesigned combustion chamber and a new, low restriction air-intake silencer with a BIA certified 75hp rating at 5500 rpm. A high-compression cylinder head was optional.
    RACING LOOPERS – The Evinrude CC & Johnson SR were 49.7-cubic inch, triple cylinder race engines based on the 75-hp Johnson Stinger & Evinrude Hustler block. These racing loopers are likely best remembered as pure factory-available, race-ready outboards. Both the 2 & 3-cylinder loopers competed in various stock production classes and race-tuned classes over the years, winning consistently. In addition, stock production motors with 15-inch lower units and high-speed Nitro gear cases also took top honors.
    MILITARY LOOPER - The 2002 US Navy Seal Enforcer 2-cylinder, 55hp submersible outboard. Designed specifically for beach landings and to be submersible with a de-watering system that could drain water from the engine, should it be intentionally or accidentally submerged. The outboard lower unit was an enclosed pump-jet system preferred by Special Forces to avoid inadvertent injury to divers in the water.
    COMMERCIAL LOOPERS – Starting with the 2-cylinder, 50hp, rope start, tiller model in 1979, these motors became highly regarded as tough and reliable working outboards around the globe, usually in remote rural locations. Over the years, 55hp, 60hp & 65hp models were added. Commercial loopers were detuned versions of the standard motors to utilize low octane, poor quality, fuel often found in 3rd world countries. They had extensive anti-corrosion coating in critical areas and more stainless steel fasteners than the regular production engines. The water pumps used a chrome-plated aluminum pump housing for longer life in muddy or sandy waters.
    Notably, Johnson commercial outboards were dominant in several countries including South and Central America. In many places there, an outboard was referred to as a “Johnson” – no matter the actual brand. In fact, someone who ran an outboard was known as a “Johnson operator.”
  5. Thanks Bob V thanked for this post
    Likes Mugs914, Bob V liked this post
  6. #12604
    Feb 2008
  7. Thanks Bob V thanked for this post
    Likes Mugs914, V pads, powerabout, 22R, Bob V, Watermark liked this post
  8. #12605
    Feb 2008
    42 Phil Wasssll Burgess/Johnson RS
    UIM OE
    Bristol GP 1980.
  9. Thanks Bob V thanked for this post
    Likes sharpeye Mike, Mugs914, Bob V liked this post
  10. #12606
    Feb 2008
    Ross Willaton
    Top contributor
    Winning my class 1977 Cowra 250 Enduro (4hrs10mins).
  11. Likes Mugs914 liked this post
  12. #12607
    Need bores bigger than a 56'er to get 1000cc out of one of those
  13. #12608
    Feb 2008
    Derrick Issitt Sealink Stena Line UIM F3
    Nottingham UK.
    Attached Thumbnails Attached Thumbnails 461699686_966803742153016_475947684700201156_n.jpg
  14. Likes powerabout liked this post
  15. #12609
    Feb 2008
    Jack Aylsworth
    Johnson Stinger - THE MEAN MACHINE
    The first ‘hot orange’ Stinger 65 was introduced in 1972 on NBC’s splashy national TV special “Discover Wet” hosted by Johnny Carson’s sidekick Ed McMahon at Cypress Gardens. By the early 1970’s, Johnson styling had become a bit conservative - and certainly not flashy!, So the introduction of a screaming orange outboard was quite jarring...if not daring from a marketing standpoint. Launched as a “1972 Limited Edition” model - just in case screaming orange was “too daring” - the 65hp Stinger was an instant hit. The 1972 / 1973 model, shared identical mechanicals with the standard 49.7 cu. in. Johnson 65 looper producing its BIA certified horsepower at 5000 rpm.
    Playing off that initial success, an upgraded 70hp Stinger followed in 1974 with a massive ‘70’ horsepower ID on its flanks. Its additional 5 horses were credited to refined tuning and improved carburetion. Doubling down on performance, horsepower increased again in 1975, now to 75. Again, festooned with a bold horsepower ID on its sides announcing its presence. Those extra 5 horses came from new exhaust ports, a redesigned combustion chamber and a new, low restriction air-intake silencer with a BIA certified 75hp rating at 5500 rpm. A high-compression cylinder head was optional.
  16. Likes powerabout liked this post
  17. #12610
    45 Post(s)
    Evinrude Match?
    Quote Originally Posted by lars strom View Post
    Jack Aylsworth
    What was the equivalent for Evinrude? Hustler? I don't recall the Evinrude having a shouting paint job? The orange paint made its way to the V4 Stinger as well. Stopped short of being used on the V6 RS. Too bad.
  18. Likes 22R liked this post
  19. #12611
    Jun 2002
    Winter Haven Fl.
    Lost my dad last week, I made a nice slideshow and found some great pictures.Click image for larger version.
  20. Thanks Instigator, lars strom, Bob V thanked for this post
  21. #12612
    Jun 2002
    Winter Haven Fl.
    A few of them.Click image for larger version.
  22. #12613
    Feb 2008
    Quote Originally Posted by oldschoolltv View Post
    So sorry for your dad..There is an older post on my OMC FaceBook page with lots of picture of your dad.
    Not sure if this link works.
    https://www.facebook.com/share/p/YS2pHmhvScapN6yv/
  23. Thanks oldschoolltv, Instigator thanked for this post
    Likes oldschoolltv, 22R, Instigator liked this post
  24. #12614
    Feb 2008
    @WaterZebra
    Attached Thumbnails Attached Thumbnails 83422927_10218482053295751_4500733015873290240_n.jpg   hustler.jpg
  25. Likes 22R, powerabout liked this post
  26. #12615
    South Florida
    [QUOT Sorry to hear about your Dad. Had a few good races with him. E=oldschoolltv;3434238]Lost my dad last week, I made a nice slideshow and found some great pictures.Click image for larger version.
  27. Thanks oldschoolltv, Instigator thanked for this post
    Likes DanUmbarger, LakeFever liked this post
Page 841 of 900 FirstFirst ... 341 741 791 817 818 819 820 821 822 823 824 825 826 827 828 829 830 831 832 833 834 835 836 837 838 839 840 841 842 843 844 845 846 847 848 849 850 851 852 853 854 855 856 857 858 859 860 861 862 863 864 865 891 ... LastLast
  1. Evinrude & Johnson Racing 1967+
    By Mark75H in forum Outboard and Racing History
    Last Post: 04-24-2023, 09:58 PM
  2. V8 Johnson/evinrude Outboards
    By baassoc in forum General Boating Discussion
    Last Post: 04-17-2020, 06:21 AM
  3. D and E Class OMC outboards, Johnson 60 and Evinrude 75
    By smokin'joe in forum Outboard Engines
    Last Post: 05-21-2017, 09:24 AM
  4. Replies: 0
    Last Post: 10-02-2014, 09:07 PM
