Results 1 to 15 of 25
09-14-2024, 06:23 PM #1
Replace 2.5 V6 with a 4-stroke. Good idea or not?
Sorry if this has been discussed eleswhere already on S&F; I couldn't find it if so. Anyway, I'm looking for some advice about putting a 4 stroke on my 1995 Brad Collins center-steerJaguar River Racer.... It currently still has its 1995 carbureted 245HP Merc Racing 2.5 V6, which runs fine- and fast- with good compression and low hours. Nothing wrong with it except the usual carbureted pre-mix 2 -stroke inconveniences. I'm thinking about moving to a 225HP 4 stroke. I believe the 2.5 is about 350 lbs. The Merc 225 "4-stroke" 3.4 litre V6 is 475lbs (listed), so 125 lbs more. From 175HP to 300 in the Pro XS line is a 511 lbs V8- 161lbs more. The Pro XS has a low water pickoff but I think the extra weight could be a problem. However, I know people do put 300HP ProXS's on these boats. I'm not after the ultimate top speed or holeshot. Any thoughts or other recommendations? Thanks in advance.
09-14-2024, 06:55 PM #2
I would leave the the 2.5 on it, but I'm a bit bias. If you insist, might try the extra weight before making the investment. 125-150lbs of sandbags at the transom should do the trick.
tedthebrit thanked for this post
09-14-2024, 07:52 PM #3
The new 200R with the factory sportmaster would be a great option. It will push that hull 100mph and be a great setup. The new DTS systems are all plug and play no more shift and throttle cables, just one harness. Cleans up the rigging a bunch. Once you go to the new R series you'll never go back.
Jr.Larry Gempp Jr.
09-15-2024, 10:40 AM #4
Excellent idea. I was thinking of carrying some extra gas cans to try it out, but sandbags would be even better.
09-15-2024, 10:43 AM #5
A couple of people have recommended the 200R. Also some say the Yamaha SHO- heavier but 300HP. I'll wait a bit and see if there's a consensus. the 200R is pretty new so there don't seem to be a lot first hand accounts yet.
09-15-2024, 11:32 AM #6
Team Member
- Lake Coochiching, Ontario
- 8,429
- 43
- 397
- 660
- 2111
- 6 Post(s)
For my boat, a 200XS is still the engine to beat until I see testing that shows otherwise. You might have trouble finding one. I think you might find any 200 a let down after running a 2.5 though.
John S liked this post
09-15-2024, 06:02 PM #7
Whatcha gonna do with the 245?
22R
aj06bolt12r liked this post
09-15-2024, 08:16 PM #8
Unless you think the boat is scary fast now and rarely open it up, I can't see how you would be happy going from a 2.5 245HP to a 200R. Thats almost 20% less horsepower. Don't get me wrong, the boat will still be fast. It may even have just as good of holeshot because of the low range torque of the fourstroke. Just not as fast as the 2.5. That boat looks like it's going to go over 85mph even with a 200. So, a ProXS with a torquemaster will not work. You risk blowout. But if the boat can handle the weight of the 511lb ProXS V8. A 520lb 250R or 300R with a sportmaster would be the ultimate.
09-15-2024, 11:47 PM #9
Good points, Skialot2. (Great name too by the way!) I think the boat's well matched to the 2.5, in fact it was basically designed for it, but I don't feel the need for every last ounce of performance any more. We actually have used the boat mostly for waterskiing and "moderate" speed cruising, which may sound like sacrilege to the Mirage devotees. But full throttle is still a blast!
09-15-2024, 11:49 PM #10
09-16-2024, 06:18 AM #11
Here's my opinion and experience. I would run your setup til it quits. That's what I did on my Triad v21. I blew the 2.5 and was ready to order a new four stroke. I got a good deal on a 3.0 pro XS and decided to go with that. So here's my experience, it's a good motor, easy starts no problems idling around the marina and the no wake zones. Great all around cruising motor. However running top end I can definitely tell the difference in the extra weight. My boat definitely likes the lightweight 2.5 better. I guess it's kind of like me gain an extra 40 or 50 lb of lugging that around all day.
09-16-2024, 02:59 PM #12
09-16-2024, 08:30 PM #13
Team Member
- 8,429
- 43
- 397
- 660
- 2111
- 6 Post(s)
I would not have thought that a 2.5 carb would be suited to water skiing. Maybe the 4 stroke does make sense, if the boat can handle the weight
09-16-2024, 09:02 PM #14
OnPad liked this post
09-17-2024, 03:54 AM #15
Good or Bad Idea
By tabme in forum Technical DiscussionReplies: 2Last Post: 10-08-2019, 05:07 AM -
would you replace a good running stator for this?
By pcrussell50 in forum Technical DiscussionReplies: 6Last Post: 07-26-2017, 08:45 AM -
good idea??
By cterrebonne in forum Technical DiscussionReplies: 2Last Post: 10-11-2006, 10:05 PM -
Good Idea?.......
By sosmerc in forum Technical DiscussionReplies: 2Last Post: 03-31-2003, 09:59 PM
