Results 1 to 15 of 20
    Aug 2005
    Knoxville , TN
    Top guided vs. bottom guided rods
    I've been playing with these mercs for a while now, but never got into building one from scratch, i.e. never touched the rotating assembly. What is a top guided rod and bottom guided rod? I know this is a basic question to some of you, but I just don't know because there aren't many around my area who play with these things. Just looking to understand some of the basics of the rotating assemblies. Thanks!
    Brian
    1995 Allison XB-2003, 225 Promax
    2002 Trans Am, pulls the boat fine.
    North Branch & Pine City, Mn.
    Top guided restricts side to side (up and down on a outboard) movement at the wrist pin area, sometimes with shims that encapsulate the pin bearing where it hangs out the sides, and a bottom guided rod is clearanced tighter to the crank side fillets for lateral movement restriction.
    Something has to hold the rod from slopping around from side to side. Top or bottom, but not both.
    The Reverend, (Cedar Machine Service on Facebook)
    1989 HST 2.5 260 Merc Offshore
    1991 Vaserette YT 200 Mercury
    1988 Venus XT 200 Yamaha
    1983 Viper II Merc 90
    1977 Viper
    Mini GT tunnel, 25 Merc
    "African Queen" pontoon 25 Merc
    Aluma fishin tub, 20 motors to choose from!
    GUESS WHAT?...I gotta fever,...and the only prescription...IS MORE COWBELL!!
    Nov 2003
    Simi Valley, SoCal
    I think there are two advantages to top guided rods. The first is more clearence on the sides of the big end for lubrication and the most important is less friction because the small end only waggs back and forth as opposed to the big end which would be rubbing all the way around on the crank.
    96 Cougar 23 MTR twin 300XS's. 100 something
    98 Laveycraft Sebring 20.2 Tunnel 280 90 something SOLD
    85 Baker RST 220 Laser SOLD
    Dec 2001
    If ya got losse bores the piston held rod is more prone to go wrong..... splecltly with plastic brearing cages..... Crank held rods are less critical with bore slop.
  5. Likes NZ Sidewinder, NICE PAIR liked this post
    Aug 2005
    Knoxville , TN
    Thanks guys! That's exactly what I wanted to know, makes perfect sense! So the 225 promax is a top guided motor then?
    Dec 2003
    Breaux Bridge, LA
    Yes it is.
    XR2001 & XB2002
    Nov 2020
    New Zealand
    This is a point that's not talked about.
    It's an old thread but very important.
    Wisecos for example collapse in the skirts and if the bore clearence was .009 to start with, which is what you want in a sreaming race motor, then the big end of the con rod is able to walk across (sag) on the crank journal due to gravity.
    That causes the rollers to grab at one end.
    Plastic cages can't handle this and Aluminium cages can't either.
    I caught this issue on the bench.
    So my policy is good pistons in a .008 bore can be top guided
    Sloppy Wisecos in a .009 bore go bottom guided with 35-40 to 1 premix fuel.
  9. Likes NICE PAIR liked this post
    Apr 2023
    Long island, NY
    I get what you are saying but I am not sure about the numbers. On my 2000 2.5 the book calls for a 3.494 piston +/-.001 It calls for a 3.501 bore +.003 allowable taper, OOR, wear. So .007 standard clearance + .001 piston wear + .003 cylinder wear = .011 clearance is still within allowable spec. If standard clearance is .007 and allowable is .011 I don't think you can consider .009 for Wisecos sloppy.
    Nov 2003
    Simi Valley, SoCal
    Quote Originally Posted by NZ Sidewinder View Post
    I'm glad you posted this. It made me think a little deeper into what's happening to the bottom end bearing. I expect that you are right about the extra wear especially at low speed (idle or "on the bench") but I also expect the force against the rollers will square up the big end under load. The journal is pretty wide and clearances are close. For sure something to think about!
  12. Thanks wolfgangb thanked for this post
    Nov 2020
    New Zealand
    I'm not referring to the book.
    I'm referring to the motor on the bench that needs to win races and to pistons that start out as one shape and end up another.
    The book is a guideline that doesn't allow for motors that are raced.
    An engine builder will build an engine based on a combination of what is in the book, what he has in front of him and what's in his toolbox of engineering experience.
    With regard Wiseco pistons.
    They have a tendency to become ball shaped in the skirts.
    This means that the rod has much less support (guiding) from the piston.
    I caught this issue on the bench when turning the rotating assembly by hand.
    After about 6 rotations the motor which was just sitting on the bench, then started to rotate as a whole, whereas up until that point it would sit still on the bench and allow the rotating assembly to move only.
    Then look at the rods through the big open 7 petal front and see that some of the rods had sunk to the bottom of the journal.
    Then take a screw driver and flick the rods back up to the middle of the journal.
    The rods flick up, don't just slide up.
    They were pinched down there.
    At speed, centrifugal force holds Then perpendicular to the crank, but it's possibly at low speed and start up where the problem starts.
  14. Likes NICE PAIR liked this post
    Apr 2023
    Long island, NY
    Ok I agree with that. Bottom guided rods would definitely support worn out ball shaped pistons better than top guided would. I would also theorize that because a bottom guided rod supports the piston straighter in the cylinder, the piston will have less of a tendency to become ball shaped in the skirts to begin with. I don't build race motors. Just a few recreational motors for myself. I won't reuse a piston with any signs of wear at all. Any piston with ball shaped skirts would be considered junk.
  16. #12
    Nov 2020
    New Zealand
    Here's a photo of a ball shaped piston from last season.
    It shows very little wear other than on the side of the top rim above the top ring.
    Put the mic on this mint looking piston and holy ****, it's a ball.
    You are correct, don't use it.Click image for larger version.
  17. Likes NICE PAIR liked this post
  18. #13
    Great info NZ, can you guestimate the running hours on that piston? For my 2.5 memory banks!
  19. #14
    Nov 2020
    New Zealand
    One season racing, maybe 20 races, 5 mins of race time each race, plus another 5 mins per race of 5000rpm milling around, plus testing which would maybe double the race time.
    So that's an approx total of 200mins at 7000rpm and 100mins at 5000rpm.
    Cooling is stock poppet and stats.
    Has diverters.
    Bottom guided, which in my opinion saved the motor.
    Pistons are plus .020 Wiseco
    Bores were fresh 3.523
    Piston skirts 3.514
  20. Thanks NICE PAIR thanked for this post
  21. #15
    Nov 2020
    New Zealand
    I'm wondering if anyone has tried taking a couple of thou off the top face of a bottom guided rod at the big end.
    Or some other mod to the big end that might help oiling.
    I have both types of rods and cranks and wristpin spacers etc but right now, based on what I've seen, I've got doubts about top guided stuff with large piston clearences.
    This may sound crazy
  22. Likes NICE PAIR liked this post
