Results 1 to 8 of 8
Thread: Pitch change
09-03-2024, 12:17 AM #1
5000 RPM
- Sep 2008
- Delaware River,NJ
- 362
- 7
Pitch change
I have a 26 Trophy plus that is just putting me over the max rpms.
A 27 would probably put me where I need to be.
If you have a prop shop add cup to reduce rpms would that be similar to running a 27 pitch or does it just lower the rpms?
09-03-2024, 12:35 AM #2
I think most stainless props can be re–pitched +/– 1" pretty easily... but really you should see if you can borrow a 27 or 28 to test before you spend the money. If you're running up against the rev limiter or even past the power peak... you might be way off?
rock liked this post
09-03-2024, 03:04 PM #3
Some older 2 strokes like to be spun hard. What engine do you have? Is it always over rpm or just when light? Does your engine have a limiter?
Jim
09-03-2024, 07:00 PM #4
5000 RPM
- Sep 2008
- Delaware River,NJ
- 362
- 7
I've made 2 responses to my post, yet they aren't posting
09-03-2024, 07:01 PM #5
5000 RPM
- Sep 2008
- Delaware River,NJ
- 362
- 7
09-03-2024, 07:02 PM #6
5000 RPM
- Sep 2008
- Delaware River,NJ
- 362
- 7
2012 250ho Evinrude. Light load.
Max HP rpm states 5800 rpms and max rpms 6000 and I wss hitting close to 6200
09-03-2024, 07:47 PM #7
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
09-03-2024, 10:03 PM #8
I agree with David and Kirshner. 1 inch change of pitch is 200 rpm generally. A 27 will drop rpm's and may go the same speed. The only way to know for sure is to try one. It will be more sluggish then the 26 loaded.
I always suggested to my customers prop the boat for how your gonna run it. Most people spend little time with a light load. I like to prop so loaded with typical load will allow you to reach max rpms's. That way the boat is responsive and fun to operate. Its no fun to run an over propped boat.Jim
What pitch Promax propeller if going from Bravo XS 25" pitch, performance/mid-range?
By Capt j in forum Props, Setup, and RiggingReplies: 0Last Post: 08-17-2021, 02:19 PM -
prop pitch change
By JERSEY DEVIL in forum PropellersReplies: 1Last Post: 02-18-2014, 04:26 PM -
prop change ? or gearcase change.
By jlay in forum Props, Setup, and RiggingReplies: 5Last Post: 11-13-2010, 09:36 PM -
Help on diameter and pitch change
By K9 eagle in forum Props, Setup, and RiggingReplies: 7Last Post: 08-11-2010, 10:08 PM -
RPM change per degree of prop pitch?
By DEYS in forum Technical DiscussionReplies: 13Last Post: 07-17-2008, 12:42 AM
