Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 77
  1. #31
    TX......somewhere?
    two handed Stihl...........
  2. Likes OnPad liked this post
  3. #32
    Nov 2021
    Northwest
    Two hands, and a foot for easier starting.
    The one lung engine is cheaper to learn porting/machining vs Merc v6. Modified a few saws, but that one has the most compression.
  4. Likes tlwjkw, David - WI liked this post
  5. #33
    TX......somewhere?
    3/8ths two handed handle starter rope if little (use ta be) like me!!!!!!!!!!!!!!!!!!!
  6. Likes OnPad liked this post
  7. #34
    Aug 2021
    What's the difference between 18787c4 and 18488c4? I got a pair of c5 I'm looking to swap for better compression
  8. #35
    Nov 2021
    Northwest
    2 litre/18787c4 has less chamber diameter, cc/volume, and a larger squish band than 2.5 litre/18488c4. Otherwise the chambers are the same shape.
ID:	535820Click image for larger version.
    On a side note. I was able to get 130lb compression reading out of the 2L heads after i removed the adapter off the end of the compression tester. Doh!!
  9. Likes LakeFever liked this post
  10. #36
    Nov 2020
    New Zealand
    Here's my workings on this.(in metric)
    2.5L engine
    Bore is 8.90cm
    Stroke above exhaust port is 3.9cm (some wriggle room on that)
    Swept volume is 242cm3.(242cc)
    Head chamber volume 30cc and squish volume is 6cm3 (6cc)
    Add all those together = 278.82cc
    Devide that by the chamber volume plus the squish volume.
    Squish is part of the chamber volume.
    278.22cc ÷ 36cc =9.27/1 ratio.
    If that's wrong then someone should pipe in and say so.
    9.27/1 is up there but ok for. Good gas and cool plugs/ piston imo
    This also assumes 100% volumetric efficiency and 0 leakage
  11. Thanks LakeFever, powerabout thanked for this post
  12. #37
    Quote Originally Posted by OnPad View Post
    Plus 8% – 9% for altitude?
    Also, you really need the SnapOn type gauge... (I think) you're giving up a couple cc because the end of your hose fitting is shorter than your actual spark plug. The void in the spark plug hole isn't there whe the spark plug is installed.
  13. Likes OnPad liked this post
  14. #38
    Nov 2021
    Northwest
    No compensation for altitude. All the guys at sea level could add 8-9% to my 130lbs. Your right there is some extra space under that Schrader valve that could account for a few more lbs. That puts it closer to the 150lbs at sea level that everyone else is claiming.
    Here I am trying to figure out a compression gauge while NZSidewinder is posting fancy corrected compression ratio calculations. What a show off.
  15. Likes David - WI, NICE PAIR liked this post
  16. #39
    Nov 2020
    New Zealand
    I've got the exact same pairs of heads in front of me right now.
    I'm aiming for 160psi.
    Here's the unknown.
    Squish protects the edge of the piston and probably the high point of the liner from the flame front during the period of piston travel where its moving much more slowly than mid stroke.
    So for 160psi, do I want to use the 2.0L head with a .040 cut or the big chamber 2.5L head with the narrower squish band and a .140 cut?
    If you draw a circle around a cross section view of this squish area, it will prove to be full of secrets.
    There was a comment here somewhere that people forget how long ago the 1980s were.
    This is correct
    I call the marine shops and automatically assume that the parts guy knows what a 2.5 merc is.
    I mean what other motors are there?
    But of course 2.5 mercs are almost extinct and the parts guy wasn't even born in the 80s.
  17. Likes LakeFever, OnPad, NICE PAIR, Baker343 liked this post
  18. #40
    Jun 2018
    Floating around
    All I can add to that is a fast boat guy I ran into at the launch who had a Bridgeport on a Ventura said he ran these heads on a 2.5 FF like mine and it worked amazing. I’ll cc mine when I get around to this mod. Maybe tomorrow if I can squeak the time in to do this
  19. Likes OnPad liked this post
  20. #41
    Nov 2021
    Northwest
    Heres a link to a interesting article.
    http://www.powercdi.com/manual/combu...squish/en.html
  21. Thanks powerabout thanked for this post
  22. #42
    Nov 2020
    New Zealand
    Just a point on cranking compression readings.
    There are two types of cylinder liners that affect compression readings at cranking speed.
    Standard and exhaust relief.
    The exhaust relief engine will have lower cranking compression compared to a similar engine without exhaust reliefs.
    This came up just today when a racing administrator suggested to me that a restricted race class could be subject to compression tests.
    I pointed out that an exhaust relief engine could have cut heads yet return low compression test numbersClick image for larger version.
  23. Likes LakeFever, NICE PAIR liked this post
  24. #43
    TX......somewhere?
    Thread: 2.0L 135 fatblock heads on 2.5L 200?
    how did we get this far off topic..... those have been around on tha 2.0, 2.4, 2.5 150/175's for a very long time.. its well known that crankin' comp is effected by a few lbs. with that liner...
    i'm still waitin' on someone ta take bone stock "fat block" 2.0 heads and bolt 'em on a 2.5 "fat block" and come up with this mystical number?????..............................
  25. #44
    Jun 2018
    Floating around
    working on it
  26. Likes NICE PAIR liked this post
  27. #45
    TX......somewhere?
    working on it
  1. 2.4 Fatblock which heads to cut? 2.4 or 2.5?
    By coffeeguy in forum Technical Discussion
    Last Post: 12-30-2014, 11:31 PM
  2. 1991 2.4 Fatblock Cutting Heads and other cheap hp gains
    Last Post: 12-27-2014, 01:54 PM
  3. Bridgeport, fatblock? what does this mean?
    By tfrizz80 in forum Technical Discussion
    Last Post: 09-27-2012, 04:13 PM
  4. Fatblock
    By Jerry Millington in forum Technical Discussion
    Last Post: 06-20-2006, 11:06 AM
