Results 1 to 15 of 32
08-12-2024, 01:37 AM #1
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
External water hoses on F1 engines
Guys
I have noticed F1 engines these days put a fitting in the top of the block and run 2 hoses down into each head between 3-5 and 4-6
Is this to try to dump any air out to get a solid water flow around the cylinders ( without dropping pressure) or add a bit of cool water over 5 and 6? ( with air in it or both)
Thanks
( yes I might be going to dark side in a carby 2.5 steel sleeve on a one piece, tunnel boat)
08-12-2024, 04:52 AM #2
nice cool water flow
08-12-2024, 06:00 AM #3
- Jun 2007
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
08-12-2024, 07:38 AM #4
08-12-2024, 07:52 AM #5
- Jun 2007
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
Just a collection of ex f1 and f2 tunnel boats with large gearbox pretty close to Texas F1 powerheads.
https://www.youtube.com/watch?v=rVKUqWVvxCE
08-12-2024, 05:40 PM #6
08-13-2024, 05:54 AM #7
is gone
Frank Molé liked this post
08-13-2024, 05:58 AM #8
- Jun 2007
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
08-13-2024, 07:43 AM #9
want you ta think about this... how/where could it purge any excess air?
08-13-2024, 08:13 AM #10
- Jun 2007
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
08-13-2024, 08:21 AM #11
right... right back into tha system............ 'bout only way air can be purged is thru tha adapter plate...
thats tha reason a hose was added down to tha poppit with tha production motors in '89.. they figured it out when tha water cooled rec/reg was over heating due ta air pockets....... worked well enough ta keep it after tha water cooled stuff went away..........
those two hoses are just for "extra coolin' water" to tha motor....Last edited by tlwjkw; 08-13-2024 at 08:30 AM.
powerabout thanked for this post
powerabout liked this post
08-13-2024, 08:25 AM #12
- Jun 2007
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
08-13-2024, 08:37 AM #13
"calf rope"
08-13-2024, 08:39 AM #14
A manually forced diverted flow. Adds another loop to the hottest parts of the block. Instead of relying on just rubber diverters in the cylinders to surround the cylinders this system pumps in to the center and out the top. The heat will naturally settle in the center of the block anyways so by routing the cooling this way it shoves the heat from the center out. That’s how it looks to me
08-13-2024, 08:42 AM #15
- Jun 2007
- 9,380
- 1080
- 421
- 4795
- 2206
- 9 Post(s)
Mercury Tech: 89 200HP Mariner Low Water Pressure - water pump and hoses flow fine
By tristanlee85 in forum Technical DiscussionReplies: 25Last Post: 07-02-2018, 10:59 PM -
External water pick up
By fcalligaro in forum Technical DiscussionReplies: 40Last Post: 05-16-2012, 02:55 PM -
External Water Pickup
By beer30 in forum Props, Setup, and RiggingReplies: 4Last Post: 03-29-2004, 08:14 AM
