Results 16 to 30 of 52
Thread: Surface running props
05-22-2024, 01:05 AM #16
6500 - 7000rpm is where I'm running with 14.5 × 28p × 4 blades, 1.87 gears, and slightly modified 200xri, and150 supermag.This combo gives a decent hole shot, good midrange, and top speeds of 75, and 82mph.
I've been wanting to try a Mazco re4 after running a re3 the other day. I think that would be a wicked fast prop in 28, or 30p. The 28p re3 put a bunch of my choppers to shame, except it had my 7000rpm tach buried and took a second to come of the stop when I lifted.
05-22-2024, 05:09 AM #17
6000 RPM
- Aug 2015
- Southeast
- 1,287
- 139
- 124
- 58
- 792
OnPad liked this post
05-22-2024, 07:13 AM #18
is that the 40 amp with the heavy flywheel? If it is stay under 7k, don't hold it all day at WOT. Now if its 16 amp with the lighter flywheel or even get a lightweight flywheel and you can turn it harder for WOT runs but still, don't go 15 miles WOT the whole way! trying to prop for 5600 or 6000 rpm is tough as you have to go so high on the pitch like you think but the take off will be horrible. Find the prop that gets you 6800-7K at max speed if you have 40 amp. if 16 amp see what it will turn WOT, maybe it will make it to 8K but I doubt it.
1973 Viper - sold
1978 Viking - sold
1995 XB02
05-23-2024, 12:15 AM #19
5000 RPM
- Jul 2021
- Pompano Beach
- 153
- 16
- 38
Promax or the new Bravo OT I think it is.....the FS/XS are pretty good too.
05-23-2024, 08:35 AM #20
Team Member
- Lake Coochiching, Ontario
- 8,466
- 43
- 403
- 669
- 2130
- 6 Post(s)
Curious. Conventional wisdom is that you can only go up perhaps 2" by having a prop re-pitched, but your 26 is faster than your 30 at 5500 rpm. Is your current prop part number on the attached chart? Is it really a 26? What is your max speed and rpm with the 26?
Overhub surfacing props that have worked well on my SS2000: Drag 4, Hydromotive T4X, small ear choppers, Hill ET copy, Hoss Triton
Through hub surfacing props that have worked well for me: Trophys, Hydromotive
I agree that the Promax would be worth a try. You don't see a lot of Bravo's on smaller boats. ETs are good for a lot of people.
05-23-2024, 11:18 AM #21
I agree, conventional wisdom say 2" on a re-pitch. Yes. It is a big ear chopper 48 89858 A-4 26P. I never had it as a 26P. On my Glastron with my 135 it ran 65MPH @ 5500 RPM. That translates to around 16% slip. If it was a 26P slip would be 4%. But that motor did not have a LWP. I ran it with the prop buried. The shaft was around 3 or 4 inches below the keel. With a LWP I probably could have got another 4-5 MPH out of it. I only used it once on the Checkmate and I never got a top speed with it. Now it's way too small for the 200 to get a top speed reading.
05-23-2024, 11:40 AM #22
05-23-2024, 12:26 PM #23
05-23-2024, 02:42 PM #24
06-01-2024, 07:57 PM #25
Are you SURE that you don't have 2.00 gear set in the lower. The numbers just don't work out.
Carter Powell
David - WI liked this post
06-10-2024, 09:23 PM #26
I have a rare to find, original Spinelli star 4 14.5 X 28.5 small shaft I can sell you. Still in like new condition.
Has great lift and holding power and very fast top end speed.1990 22' Activator Yami HPDI 300-sold-86.4
1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
1982 21' Superboat 300merc-87
1990 22' Activator yami OX66 Vmax 250-84.2
1982 30' Scarab-twin 200 Merc-sold
1979 21' Challenger 300 Evenrude-sold
1979 21' Superboat 200 Merc-sold-72
06-12-2024, 11:05 PM #27
06-12-2024, 11:34 PM #28
I finally got out on the boat again. I think the tach may be off a little. I tried all the different settings. Only one setting is even close. My prop slip number just does not add up. I can see in the video I do hit 7000 RPM. and my phone GPS says a max speed of 68. That is a slip of 36%. Even if the prop wasn't modified and still a 26P it would be a slip of 26%. Got some video with a good look at my gauges. Around 4:44 of the second video you can see 7000 on the tach, and several other spots. Does it sound like 7000RPM?
1989 Checkmate Spectra 171 (youtube.com)
1989 Checkmate Spectra 171 (youtube.com)Last edited by skialot2; 06-12-2024 at 11:50 PM.
06-12-2024, 11:38 PM #29
Something just doesn't add up. I've seen actual tach error of 200 rpm @ 6400... but that's not enough for what you're seeing.
06-12-2024, 11:49 PM #30
Low Friction paint - running surface.
By Down Under in forum Technical DiscussionReplies: 9Last Post: 05-30-2006, 03:29 PM -
Placing Epoxy Resin over aluminum running surface???
By 150aintenuff in forum Fiberglass and Composites DiscussionReplies: 8Last Post: 01-12-2005, 12:09 PM -
sanding running surface
By fullcharge in forum Fiberglass and Composites DiscussionReplies: 9Last Post: 06-20-2004, 12:51 PM -
running surface
By Quick Rick in forum Fiberglass and Composites DiscussionReplies: 5Last Post: 02-17-2004, 12:35 AM -
Running Yamaha props on Mercs
By jrpromax in forum Technical DiscussionReplies: 3Last Post: 01-11-2002, 10:44 PM
