Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 46 to 60 of 64
  1. #46
  2. #47
    May 2024
    Tennessee
  3. #48
    May 2024
    Tennessee
    Is this the way the poppet valve should be plumbed
  4. #49
    Quote Originally Posted by whitehead249 View Post
    Can't even see it. It's on the starboard side of the block below the switchboxes.
    May 2024
    Tennessee
  6. #51
    Ya gotta shoot it from the side so we can see the cover. I do see a suspicious looking hose there though.
    May 2024
    Tennessee
  8. #53
    Ok I see the bypass from the top of the block to the cover. That looks ok. Is this powerhead on your old midsection and exhaust plate?
    May 2024
    Tennessee
    This is the motor I bought power head and mid section is all the same the way I bought it. It’s the one I’m having over heating problems
  10. Thanks transomstand thanked for this post
  11. #55
    Cudjoe Key FL
  12. #56
    Is the serial number on the decal on the clamp bracket the same as the powerhead?
    May 2024
    Tennessee
    I just left but when I go back I’ll get those numbers for you. I have it in Mamaw’s garage she lives like 20 minutes from me. I did compression test today just to make sure I wasn’t throwing money at a dead motor. I got 125 on all 6 cylinders so it’s a good motor just have to figure it out.
  14. Likes transomstand liked this post
  15. #58
    TX......somewhere?
    coupla things?.. it has bleed bibs in tha cylinders?.. 225's don't... could have been added with tha carb conversion?.. can't tell if front is five or seven petal?.. since reed plate is painted might be a five.. had an electric fuel pump also.. vacume is plugged.. looks ta be a hodge podge pro max...
    Merc says that number is a '98 225...... is a "zero" G, not an O...
    need better pics of front half and/or sides showing tha carb/reed plate mounting bolts... need side/rear pictures of tha plate/plates under tha block............
    where did you get tha idea it was an '88?... it has "bucket cowl..
    after blowin' it up several times it looks ta be a seven petal reed plate ('91 200) with wh's... would work for me!.............. if they took tha time and effort ta add tha bibs on tha cylinders kinda proves they weren't amateurs!
  16. #59
    May 2024
    Tennessee
  17. #60
    May 2024
    Tennessee
    This all the pics I have until I go back and work on it some more.
  1. 1988 200hp black max 2700 Lake Lanier GA
    By BrownEyedGirls in forum Outboard Engines
    Last Post: 04-29-2020, 09:11 PM
  2. 1988 Mercury 200 Outboard Overheating at high RPMs
    By K-DOGG in forum Technical Discussion
    Last Post: 08-10-2016, 03:13 PM
  3. OMC 97 200HP overheating
    By wfowahoo in forum Technical Discussion
    Last Post: 02-08-2007, 05:48 AM
  4. merc upgrades 1988 200hp black max
    By david martin in forum General Boating Discussion
    Last Post: 12-05-2005, 09:07 PM
  5. Merc V6 200hp overheating
    By tindell1 in forum Technical Discussion
    Last Post: 01-21-2005, 11:28 PM
