Results 1 to 15 of 28
03-31-2024, 01:55 PM #1
6000 RPM
- Aylesford Lake,NS Can.
- 1,768
- 36
- 7
- 170
Help!! What is the Easiest Way to Get 3M 4200 Sealant to Release??
I used 3M 4200 sealant when re-installed my low water pick ups on my Cougar after having them powder coated purple. I think they need to go a little lower as I am not getting the water pressure I should be getting. I stuck them on really well and I can't get them to release from the hull. Is there a method to soften the sealant up, so that I can break them free?? I tried using a heat gun but that didn't work. Any help would be greatly appreciated as the ice is out of the lake and the boat is not ready to go.
Thanks
Gary
03-31-2024, 02:17 PM #2
Be very careful, you can pull gel cote off. Don't ask me how I know! If the is any gap @ any corner try some of that man'killer braided line the bass guys use use. tie a piece 16" long on 2 handles start it @ a corner and saw it off. The line will cut your fingers. Good Luck!
OnPad liked this post
03-31-2024, 02:47 PM #3
Get out your cutting torches
razer blade
Kidding. Propane torchWe have invented the world; WE see
03-31-2024, 03:05 PM #4
LPS Zero-tri does a good job but it’s about $20/can
I’m used to using it on crankcase gasket surface, and it needs penetration, so in your application it might be tough as you’re only working the edge.
Steady pressure is better than impacts. The more you can pry and wedge without damage is your best bet.
”Chisel” spray gasket remover might work too.Last edited by HydroSkreamin; 03-31-2024 at 03:08 PM.
A problem is only a problem when viewed as a problem...
03-31-2024, 03:42 PM #5
wide wood chisel propane torch
03-31-2024, 04:11 PM #6
NICE PAIR liked this post
03-31-2024, 04:40 PM #7
Man, they look deeper in the water than any I've ever seen... before you go through all the trouble, are you there's not another problem?
03-31-2024, 05:03 PM #8
5000 RPM
- May 2019
- Georgia
- 334
- 104
- 61
- 465
- 316
- 3 Post(s)
Goof Off is the best product I’ve found for removing old glues and adhesives of any kind. Not harsh on the gel coat either. Might take some time for it to work it’s way under all that metal, though.
03-31-2024, 05:22 PM #9
30 years ago, I bought an Action with a 260 on a jack plate, I took the bolts out and jerked on the LU and she refused to move
The guy worked as an aircraft mechanic. He said it's what they use on planes. I used a propane torch to make it let go cleanly.
But I had all that weight just being held on by a 3M product I imagine.We have invented the world; WE see
04-01-2024, 06:59 AM #10
6000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,672
- 70
- 644
- 3975
- 5881
hydra-sports liked this post
04-01-2024, 07:02 AM #11
is gone
04-01-2024, 12:16 PM #12
6000 RPM
- 1,768
- 36
- 7
- 170
04-01-2024, 12:18 PM #13
04-01-2024, 12:44 PM #14We have invented the world; WE see
04-01-2024, 12:46 PM #15
Lookie what I found!
https://www.bigshrink.com/DeBond-Adh...er_p_2457.html
Biesemeyer Jet Boat $4200/Trades?
By faztbullet in forum Ebay Listings and Other Internet ListingsReplies: 0Last Post: 11-10-2016, 08:42 PM -
Trial Blazer 4200 engine
By Euroski in forum Tow Vehicles and TrailersReplies: 17Last Post: 06-07-2006, 08:01 PM -
SetBack Removal w/cured 4200 ???
By SUPERBASH in forum Props, Setup, and RiggingReplies: 19Last Post: 04-21-2006, 09:17 PM
