Results 1 to 15 of 28
    Aylesford Lake,NS Can.
    Help!! What is the Easiest Way to Get 3M 4200 Sealant to Release??
    I used 3M 4200 sealant when re-installed my low water pick ups on my Cougar after having them powder coated purple. I think they need to go a little lower as I am not getting the water pressure I should be getting. I stuck them on really well and I can't get them to release from the hull. Is there a method to soften the sealant up, so that I can break them free?? I tried using a heat gun but that didn't work. Any help would be greatly appreciated as the ice is out of the lake and the boat is not ready to go.
    Thanks
    Gary
    Be very careful, you can pull gel cote off. Don't ask me how I know! If the is any gap @ any corner try some of that man'killer braided line the bass guys use use. tie a piece 16" long on 2 handles start it @ a corner and saw it off. The line will cut your fingers. Good Luck!
  3. Likes OnPad liked this post
    PARADISE /Naples
    Get out your cutting torches
    razer blade
    Kidding. Propane torch
    Feb 2006
    Formerly Central WI/LOTO Currently PHX AZ
    LPS Zero-tri does a good job but it’s about $20/can
    I’m used to using it on crankcase gasket surface, and it needs penetration, so in your application it might be tough as you’re only working the edge.
    Steady pressure is better than impacts. The more you can pry and wedge without damage is your best bet.
    ”Chisel” spray gasket remover might work too.
    A problem is only a problem when viewed as a problem...
    PARADISE /Naples
    wide wood chisel propane torch
    Oct 2021
    Bradenton, FL
    Quote Originally Posted by NICE PAIR View Post
    Wow! That is some good info right there. I'm going to change my jack plate this month, so I will try that. Thanks
    Rich
  8. Likes NICE PAIR liked this post
    Man, they look deeper in the water than any I've ever seen... before you go through all the trouble, are you there's not another problem?
    May 2019
    Georgia
    Goof Off is the best product I’ve found for removing old glues and adhesives of any kind. Not harsh on the gel coat either. Might take some time for it to work it’s way under all that metal, though.
    PARADISE /Naples
    30 years ago, I bought an Action with a 260 on a jack plate, I took the bolts out and jerked on the LU and she refused to move
    The guy worked as an aircraft mechanic. He said it's what they use on planes. I used a propane torch to make it let go cleanly.
    But I had all that weight just being held on by a 3M product I imagine.
    Cudjoe Key FL
ID:	531446Click image for larger version.
ID:	531447Use this with a sharp scraper blade. Make sure not to get under the gel.
  13. Likes hydra-sports liked this post
  14. #11
    Moline,Ill
    is gone
  15. Likes Frank Molé, NICE PAIR, sonicss33, 108, RBT liked this post
  16. #12
    Quote Originally Posted by BUZZIN' DOZEN View Post
    Buzzin' Dozen
    I like this option but I checked with my local marine store and they are not able to get it anymore. Do you know of a source to find it that will ship to Canada? I do have 3M adhesive remover now but I haven't tried it yet. Thoughts??
    Thanks
    Gary
    Aug 2012
    Tenkiller Lake, OK
    This stuff does work!
  18. #14
    PARADISE /Naples
  19. #15
  1. Biesemeyer Jet Boat $4200/Trades?
    By faztbullet in forum Ebay Listings and Other Internet Listings
    Last Post: 11-10-2016, 08:42 PM
  2. Trial Blazer 4200 engine
    By Euroski in forum Tow Vehicles and Trailers
    Last Post: 06-07-2006, 08:01 PM
  3. SetBack Removal w/cured 4200 ???
    By SUPERBASH in forum Props, Setup, and Rigging
    Last Post: 04-21-2006, 09:17 PM
