Page 5 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 61 to 75 of 78
  1. #61
    Aug 2023
    Live Oak FL
    If it come to building a pad, which it probably will I'll probably template what's on my brother's venture. Similar size, weight and engine.
  2. #62
    Mar 2022
    Lake Travis Texas
    An Allison pad bottom
    Jim
  3. Thanks NICE PAIR thanked for this post
    Likes LakeFever liked this post
  4. #63
    Aug 2023
    Live Oak FL
    This is how his rides at about 70Click image for larger version.
  5. Likes NICE PAIR liked this post
  6. #64
    PARADISE /Naples
    113 mph, Mod Pro set up 1/4 mile, spinning a 24, over 10,000 rpm with 1:87
    If you notice, I'm not trimmed. Ben is not, either.
    A race boat at top speed should have 0 to 2-degree negative trim with proper setup...
    Your boat should have positive trim, to a small degree, not a lot.
    It's about balance. Set up is the game.
    Yes, props are part of it, but many other factors are included.
    The second picture I just went over a boat wake, on the other side of that picture were 50 boats parked on the shore
    River Ranch, a child could drive my boat 100 mph, has no unusual characteristics, boring
    11.5 inch flat pad, with an Allison lip on the sides of the pad, not in the rear like an Allison.
  7. Likes NRAINES38 liked this post
  8. #65
    Ontario, Canada
    Quote Originally Posted by NRAINES38 View Post
    It does actually have a pad.
    From what i can see in your picture, it seems like a very shallow 'pad'. This design may not be giving you much separated lift. Also, your vee section is fairly low deadrise, so benefit of a good pad is somewhat limited.
    Here's an article on 'Pad Design' that may be interesting for you.
  9. Likes OnPad, NICE PAIR, David - WI liked this post
  10. #66
    Aug 2023
    Live Oak FL
    Any opinions? Too much, too little, concave the outside edge?Click image for larger version.
  11. #67
    PARADISE /Naples
    Oh BOY,
    KISS
    Keep It Simple S
  12. #68
    Aug 2023
    Live Oak FL
    Too much? Lol
  13. #69
    Apr 2023
    Long island, NY
    I have never added a pad to a hull, but I would take the little piece out that the jack is touching. Leave the big flat board for the pad. But extend it to the edge of the wedge pieces you made. Make it a 90 up to the original hull. I would want a big flat tabletop area as a pad to balance on. I would go about halfway up the hull and then blend into the original hull shape.
  14. Thanks NRAINES38 thanked for this post
  15. #70
    Nov 2021
    Northwest
  16. Thanks NRAINES38 thanked for this post
    Likes NRAINES38, David - WI liked this post
  17. #71
    Jun 2018
    Floating around
    If your set on doing this id use foam core and laminate it on the exterior skin of the existing hull. I would not cut the hull. Id use a DA sander with 30 grit and sand the gel carefully to exposed glass and shape the core to fit perfectly as possible. Then use corebond or carefully thickened vinylester resin to bond the core down. Cover with 1708 and again vinylester resin. Cap with csm and fare to shape. Prime and seal with duratec vinylester primer. Gel and cut polish or if being lazy use non ablative speed coating hull paint. You want it straight and sharp and symmetrical. Dead center no offset at all. The surface finish should be rough to break tension with the water.
    Your going to want to flip that hull over imo. I cant imagine trying to do this off my back laying down. This is a considerable amount of work your looking at here.
  18. #72
    Aug 2023
    Live Oak FL
    Yea it took me about 5 minutes of sanding on my back last night to quit and start un rigging everything. I got plenty of shop and the tractor so shouldn't be too bad just have to set up the heaters when I start on the resin, not terribly cold here but don't want to risk it. It will be alot of work but for me that's why I have a boat, always something to do. I'll keep everyone updated as I make progress. Thanks everyone for the help.
  19. #73
    Feb 2011
    HUDSON, FLORIDA
    im on board with the table top post, to compensate for your shallow V; I would go deeper than your mock-up shows, and stop it about 8'' short of the transom. that concept moves the planning surface forward, makes the bow easier to lift. today is nice for bottom work! on second thought you could 12'' on the recess transom notch, to lengthen the pad can add a 2x2 0r 2x3 alum angle, the width of the pad across the back. the notch also feeds more water to the prop when planing off. Art.k
  20. #74
    Aug 2023
    Live Oak FL
    Dang sure is.
  21. #75
    Jun 2018
    Floating around
    Process i gave you what i have. Pad shape, width, length, position? Your guess is as good as mine. I know id be keep it as simple a design as possible so if i wanted to change something about it, it would be easier. Width id base that on weight of the hull and compare to other hulls pad size/weight and make the decision that way
  1. The struggle is real
    By Pachanga_rick in forum General Boating Discussion
    Last Post: 10-27-2020, 09:30 PM
  2. Hydrostream Valero, Which Prop? need more bow lift less stern lift,
    By Dregsz in forum Props, Setup, and Rigging
    Last Post: 05-03-2018, 08:47 PM
  3. The struggle is real...
    Last Post: 07-21-2017, 04:41 PM
