Results 16 to 30 of 33
    Quote Originally Posted by mrpenguin View Post
    4.6 liter V6 350hp is the rumor on the other websites.
    Is this what you meant?
    this was released 20 mins ago in Autralia
  2. #17
    my favorite part of the new V6 4.3L 350HP is the integrated electro-hydraulic steering
  3. #18
    That looks like the cowl in your first post.
  4. Likes noli liked this post
  5. #19
    yes sir, I do believe that is the top portion of the new cowl
    looks different than the image below...there must be other engine reveals...
  6. #20
    The back (post #17) matches the part that shows in post #1.
  7. Likes noli liked this post
  8. #21
    Lake Coochiching, Ontario
    Quote Originally Posted by aj06bolt12r View Post
    I don't care unless it weighs less than 450lbs, makes at least 225hp, turns at least 7kRPM and has solid mounts and a lower unit comparable to a sporty...
    I am not interested even with those specs. Per the engineering explained video, an efficient car would use 105 gallons of 10,000 psi hydrogen to go 300 miles. This would fill the interior of a lot of cars. A hydrogen powered boat would have all its interior space devoted to fuel storage, or it would have enough range for some short wakeboarding and water ski runs.
  9. #22
    Dec 2009
    middle tennessee
    Quote Originally Posted by David View Post
    That is true, I was not thinking about a hydrogen engine..
  10. #23
    Apr 2023
    Long island, NY
    Ok. I just watched the videos on the new Yamaha 4.3L V6 350HP. It's not Hydrogen powered. It is gas powered. They said it is the lightest in its class at 286kg = 629lbs. That is 66lbs less then Mercury's Seapro 350 or 400R V10 at 695lbs. But 117lbs. heavier than the 300R at 512lbs. I would think if a boat can hold a 629lb outboard, it could also hold a 695lb. motor. I would also think a boat big enough to hold a motor that big could benefit from the extra torque generated from the extra 4 cylinders. For some reason torque ratings are never mentioned on outboard motors. I would think a V10 would have a lot more low end torque than a V6. Anyway, I think Mercury is going to figure out a way to pump up the 512lb 300R or the 527lb. 300HP Seapro to 350HP. But they are all way to big for my 17' boat.
  11. Thanks noli thanked for this post
    Likes noli, Instigator liked this post
  12. #24
    Aug 2013
    Oshkosh, WI
    89 octane and only 6k RPM as well, the big selling point of the V10 Verados is 87 octane, 6400 RPM and the 2.08 gear ratio makes them stump pullers
  13. Likes Speed Jr. liked this post
  14. #25
    Bristol, WI
    Quote Originally Posted by Petey View Post
    And a true surfacing option.
    Larry Gempp Jr.
  15. #26
    12 Post(s)
    I thought the v-10 was close to 900 lbs???
    As in, clearly aimed at replacing twins.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  16. #27
    PARADISE /Naples
    V10 695 lbs. just 200 off
  17. #28
    Oct 2005
    savannah,ga
    Glad to see Yamaha upping their game on the big motors. And thank you Mercury for being the industry standard for big power.
  18. Likes Instigator, AlliStan liked this post
  19. #29
    Aug 2023
    Finland
    Interesting how much different it is to the Yamahas 4.2 V6. When comparing to 4.2 F300 it is almost 1kg heavier per 1 increase in horsepower.
    Any ideas where the increase in weight comes from? Much more robust / thicker engine block? If so I would imagine that would make it to have good potential for ECU and aftermarket power increases.
    4.2 is possible to ECU tune to ~330hp and Nizpro offers a 500hp supercharger kit for it and there is a video of them pushing it to 633hp. It will be interesting to see what kind of stuff Nizpro will be offering for the new 4.3.
  20. Likes David - WI, Instigator liked this post
  21. #30
    Yamaha Motor Acquires Electric Marine Propulsion Manufacturer Torqeedo
  22. Likes CUDA liked this post
  1. YAMAHA F350 4 Stroke V8 Outboards
    By steve123 in forum Outboard Engines
    Last Post: 02-09-2017, 10:47 PM
  2. 2- 1999 Yamaha OX66 250 hp outboards
    By steve painter in forum Outboard Engines
    Last Post: 10-26-2016, 07:02 PM
  3. Outboards stolen on news
    By OMCD in forum General Boating Discussion
    Last Post: 10-27-2012, 06:07 AM
  4. Yamaha Outboards
    By getreal in forum General Boating Discussion
    Last Post: 05-27-2004, 10:05 AM
