Results 196 to 210 of 308
11-22-2023, 09:37 PM #196
The Historic Photo Master
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20530
- 4 Post(s)
11-22-2023, 09:38 PM #197
- Jan 2004
- Florida
- 38,758
- 78
- 1778
- 385
- 20530
- 4 Post(s)
...gunna havta sink her deep at the ramp ta floatr tom...
Tom Smyth liked this post
12-03-2023, 10:43 AM #198
WELL IT HAS BEEN ALMOST 2 YEARS, but the wood work is finally done. Looks like a boat again. finishing details, more epoxy coats , paint and then rigging. Have learned a LOT and have to shout out to MARK NELSON for his guidance and expertise through this process. Enjoy the pics...
12-08-2023, 04:03 PM #199
Wheeled it out, gave it a good vacuum and rinsed out the inside. First bath. Getting ready for final coat of epoxy…….
12-24-2023, 08:19 PM #200
taking a break from the boat to build the powerhead for the 1350 that will go on it. Be back on the boat in January.. Merry christmas to all...
12-25-2023, 09:03 AM #201
5000 RPM
- Mar 2016
- cincinnati, ohio
- 695
- 151
- 36
- 287
- 205
NICE PAIR liked this post
12-25-2023, 09:12 AM #202
01-13-2024, 07:19 PM #203
A few quick pics of the powerhead...
01-14-2024, 11:18 AM #204
5000 RPM
- Mar 2016
- cincinnati, ohio
- 695
- 151
- 36
- 287
- 205
That's cheating, using two rings instead of three, are they a little easier to install or do they still go dink, crap broke one, start over??? What do you use to hold the bearings in place when you install the piston pin and the rod on the crank?? Looks great, good luck.
01-15-2024, 10:05 AM #205
Beautiful restoration, gonna be fun. too bad about farsebook.
01-15-2024, 08:48 PM #206
I agree, the details in restoration look great. Is it new hardware or are you having the original stuff replated? No facebook for me either…. Thx
01-16-2024, 06:02 AM #207
01-20-2024, 09:18 AM #208
5000 RPM
- Mar 2016
- cincinnati, ohio
- 695
- 151
- 36
- 287
- 205
Was checking out your thread on Inlines only and have a couple questions. What kind of spark plugs are those and have you ever considered opening up the reed stops a little, opening up the holes in the reed blocks a few thou, removing the bolt holding them together under the carbs???? Thanks for your time
02-05-2024, 08:34 PM #209
Motor is done. Time to get back on the boat….
02-13-2024, 10:22 AM #210
after a fisheye problem on the last coat, finally got a good 4th coat of epoxy on the topside. Wet sanding time... 600 then 1000 then 2000 then final buffing .
18’ Baker Tunnel Restoration
By Pilotryan in forum Boat Build-Ups and RestorationsReplies: 8Last Post: 01-11-2022, 01:08 PM -
Allison XST18 Restoration Complete
By freeebird in forum General Boating DiscussionReplies: 7Last Post: 07-14-2021, 08:03 PM -
Phantom 25 - 30 years ol getting complete restoration
By Toffen in forum General Boating DiscussionReplies: 16Last Post: 05-23-2015, 11:56 AM -
Engine height on DelCraft Wooden Tunnel Hull:
By Marchettih2o in forum Props, Setup, and RiggingReplies: 7Last Post: 06-25-2010, 12:11 AM -
14' DelCraft Tunnel & 850XS W/SSM:
By Marchettih2o in forum Props, Setup, and RiggingReplies: 4Last Post: 10-22-2007, 09:23 AM
