Results 1 to 15 of 27
Thread: Wrinkle finish lower
08-18-2023, 08:20 PM #1
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
Ive used wrinkle finish spray with great results. the temp of the surface has a huge effect on the final finish. the higher the temp the tighter and harder the finish using a heat gun, while wet, gives a rpck hard wrinkle. i am thinking about doing my newly coned lower unit.. i know it will hold up, ??heard it might REDUCE drag. it sure would look cool. what u guys think?
Instigator liked this post
08-18-2023, 08:42 PM #2
All you can do is try it. I bought some I bought textured powder coat powder but have work to do on my lower unit first... https://www.eastwood.com/hotcoat-pow...k-texture.html
08-19-2023, 08:02 AM #3
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
I did some reasearch on hydrodinamics, and yes i will reduce drag in a turbulent liquid. im gonna go 3'' below cav down to skeg. all black now, might do the gray W F. See ya, Art
08-19-2023, 08:46 PM #4
When I was racing kneel down OB Hydros the common consensus was that sharks were the fastest creatures in water and their skin was very porous/rough.
Never saw it tested though.
Try it!
My guess is, if your boat is fast enough, it will cause turbulence and then cavitation.
But, like I always do, I ask all the experts then do it anyhow!
I am probably 8/6 of right Vs wrong.
Try it!I'd rather be competitive w/junk I built in my garage than win w/stuff I bought.
Checkmate 16' 140 Johnson
Laser 480 (?) 21' w/GT 200
24' Sonic w/twin 250 Johnsons
08-20-2023, 06:40 AM #5
it only becomes effective when your breaking surface tension, a case that's already running in chopped surface likely won't see any benefit! put your golfball finish on the running surface of the pad!
08-20-2023, 08:38 AM #6
08-20-2023, 09:36 AM #7
I remember someone in Canada set a speed record in a Allison, 20 some years ago
and they used a version of the golf ball surface on the pad area.
I know some that blunt the nose cone area
08-20-2023, 03:50 PM #8
Wrinkle finish on a gearcase is good for at least 12 MPH.
08-20-2023, 05:33 PM #9
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,962
- 599
- 100
- 523
- 632
08-20-2023, 08:09 PM #10
5000 RPM
- May 2019
- Georgia
- 338
- 105
- 63
- 476
- 317
- 3 Post(s)
08-20-2023, 09:33 PM #11
08-21-2023, 01:14 PM #12
The Historic Photo Master
- Jan 2004
- Florida
- 38,618
- 78
- 1789
- 385
- 20602
- 5 Post(s)
08-22-2023, 02:38 AM #13
08-22-2023, 02:56 AM #14
Titus (or Tooter? ) used to leave the submerged part of the lower in primer rather than smooth gloss paint... but I can't find a picture right now.
Jimboat liked this post
08-22-2023, 03:09 AM #15
seen alot of 'em that way.. most of tha ones i had were finished that way.. not real "slick" but not anywhere close ta "wrinkle" either..
David - WI liked this post
R/h 14.25 x 29 srx pro finish
By K9 eagle in forum PropellersReplies: 8Last Post: 01-15-2017, 03:41 PM -
Lab finish
By outasite in forum Technical DiscussionReplies: 7Last Post: 06-26-2012, 10:35 AM -
Lab finish.........
By Blubyu in forum Props, Setup, and RiggingReplies: 4Last Post: 07-27-2004, 06:08 PM
