Page 8 of 21 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 LastLast
Results 106 to 120 of 310
  1. #106
    Jun 2001
    West system epoxy and silica filler
  2. #107
    Jun 2001
    progress today on the port sponson. First piece of ply fitted and installed. Forward piece was fitted and cut to rough size. Backing block for the joint between the two pieces also cut for exact fit between the stringers, laminated and ready to install. FINALLY putting pieces back ON the boat instead of taking it apart...
    Attached Thumbnails Attached Thumbnails IMG_0770.jpg   IMG_0772.jpg   IMG_0773.JPG   IMG_0776.jpg   IMG_0777.jpg
  3. Likes 89LASER liked this post
  4. #108
    45 Post(s)
    Quote Originally Posted by Tom Smyth View Post
    First piece of the bottom is in. Also the tabs to support the ply between each of the tunnel stringers. Don't have the fancy equipment to do a nice skarf joint. Originally built with a butt joint so that is what i am using. Maybe the second piece in tomorrow. Still wont float yet !!!!!!!!!
    Scarf joint much better than a butt joint and doesn't have to be backed up with substructure either...........
  5. #109
    45 Post(s)
    Tunnel bottom in and bonded. Working on the corner pieces. Then about 400 screw holes to fill and sand
    In today's world if race boats were built out of wood, the skins would be ka-chinked on with air driven staples..........much quicker! Seebold and other builders went to the trouble of using aluminum screws to save weight. Trouble was that no race boat was expected to last over 4-5 years. You could have a perfectly maintained hull and the paint or epoxy finish would end up bubbling up at the screw locations with powdered corrosion.
  6. #110
    Jun 2001
    Quote Originally Posted by WaterZebra View Post
    Yeah not worried about weight at this point in the boats life. Stainless screws on the tunnel bottom. Sponson sides will be epoxy and stainless staples. Sponson bottoms stainless ring neck nails and screws with epoxy everywhere
  7. #111
    Jun 2001
    little bit of progress. Starboard sponson side glued in place. soon to start on the sponson bottom running surfaces...
    Attached Thumbnails Attached Thumbnails IMG_0868.jpg   IMG_0866.jpg   IMG_0865.jpg
  8. Likes motexas, Jimboat, 89LASER liked this post
  9. #112
    Jun 2001
    both port and starboard sponson side panels installed and planned to final size. Started laying out the port sponson bottom running surface, 9 MM okumi play. Test fit to insure proper location and laying out and pre drilling fasteners locations. Reinforced on of the ribs to be wider and placing the running surface joint directly over that position. (thank you Mark). Waiting on ring shank nails. Maybe get this installed late this week...
    Attached Thumbnails Attached Thumbnails IMG_0879.jpg   IMG_0877.jpg   IMG_0872.JPG
  10. Likes 89LASER, scott reierson liked this post
  11. #113
    Jun 2001
    progress. Skins on the Port side sponson. filling screw and nail holes in the nice cool florida weather.... NOT !!! ITs friggin HOTT !!!!!!!!!
    Attached Thumbnails Attached Thumbnails IMG_0891.jpg   IMG_0892.jpg   IMG_0893.jpg
  12. Likes scott reierson, 89LASER liked this post
  13. #114
    45 Post(s)
    The boat originally had no rear cowling. Greg added one sometime during his ownership of th eboat. I have a flexible rear cowling for th eboat but plan to add ribs to it to make it a bit more conventional.
    Somewhere in the past, this boat had Evinrude Strangler power and a rear cowling. It wasn't Greg, do you know who?
  14. #115
    May 2001
    Madison, WI
    That closeup of that chine/bottom joint looks awesome! Cool! Very nice work.
  15. #116
    Jun 2001
    yes Ron Baker also raced this boat with OMC power.
  16. Likes 89LASER liked this post
  17. #117
    Jun 2001
    botom being sanded and the first of three coats of epoxy being applied. Such fun in the 96-degree Florida heat... Roger H where are you when i need you ??????
    Attached Thumbnails Attached Thumbnails sanding epoxy coat 1.jpg   after epoxy coat 1.jpg   after coat 1 prior to sanding.jpg
  18. #118
    Jun 2001
    And what else to do at 5 am other than mix epoxy, chill it in an ice tray and apply a little bit to beat the Florida heat ?
  19. Likes Hydrovair liked this post
  20. #119
    Oct 2013
    Palm Bay Florida
    Looking good Tom, Why the difference in the chine on the pads?
  21. #120
    Jun 2001
    That’s the way it was originally built.
  1. 18’ Baker Tunnel Restoration
    By Pilotryan in forum Boat Build-Ups and Restorations
    Last Post: 01-11-2022, 01:08 PM
  2. Allison XST18 Restoration Complete
    By freeebird in forum General Boating Discussion
    Last Post: 07-14-2021, 08:03 PM
  3. Phantom 25 - 30 years ol getting complete restoration
    By Toffen in forum General Boating Discussion
    Last Post: 05-23-2015, 11:56 AM
  4. Engine height on DelCraft Wooden Tunnel Hull:
    By Marchettih2o in forum Props, Setup, and Rigging
    Last Post: 06-25-2010, 12:11 AM
  5. 14' DelCraft Tunnel & 850XS W/SSM:
    Last Post: 10-22-2007, 09:23 AM
