Results 1 to 10 of 10
Thread: water intrusion 1979 Merc 115
06-20-2023, 05:40 AM #1
I am getting water intrusion in number 2 cylinder. Where would it be coming from?
Here is a little info.
06-20-2023, 06:02 AM #2
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,352
- 9
- 265
- 31
- 733
Most likely a leak on the inner exhaust baffel plate,the one right over the exhaust ports.I don't think it's available new and takes special treatment to be reused,give a call,305-394-3354,Chris
06-20-2023, 11:11 AM #3
He's right.
Pain in the ASS to fix. Especially salty motors...all the exhaust cover bolts wanna break. The inner baffle/water jacket cover is actually still available from merc @ $225. The outer baffle and outer cover are the ones that are nla...and at such a big span and likelihood to warp they are just as tricky. Did one on an 85 mariner 115 last year. I fixed it but it was not worth the time. Probably $1200+ in shop time from start to finish...and theres no way to bill someone that much for fixin a $1000 motor lol. Not to mention the epoxy mercury made to install those bolts with they don't make anymore, and the 20 yr old stuff we had here was no good anymore...
If Chris is willing to help you out on this one take him up on it...there are not many left who will do that for you!
07-07-2023, 08:27 PM #4
Ok good news / bad news.
Been working on the merc 800 just so I can keep the boat on the water. Have plans the end of the month to take the boat up to the family reunion to take the kids out and play. So the 800 is working well. Water pressure seems low. connected the water line to the middle back port at the top of the jugs, cylinder block cover, ( showing only 8 to 10 psi ) witch I believe may be the wrong placement. Should water pressure pickup point be instead hooked up at the lower portion of the exhaust manifold cover? I purchased a new impeller, but current one seems to be pissing fine all the time.
Ok now back to the 115.
Good news.
Got her torn apart. Everything came apart pretty easy. Previous owner replaced gaskets 2 years ago. after talking to him I found that he used ant seize on the inner exhaust plate bolts instead of the epoxy or red loctite. Everything came apart pretty easy, but everything seemed still snug. Found that the gasket walked or squeezed out a bit on number 4 and looked the same on number 2, while number 2 ended up failing fully where number 4 looked like it was about to give our. So no cracks and I found where the water was coming from! YAAAAAA!
Now the bad news.
This leads me to my own dilemma on what to do next. number 1 piston has some pretty good scoring, ring shows score as well. ring may be pinched in the piston in this spot. surprised I still have 115psi compression. but this explains the lower compression in this cylinder. little bit of scoring in number 2. 3 and 4 looked good on the exhaust side, to be honest I didnt even look at 5 and 6. I may want to look at 6 as it was another cylinder that was a little bit lower on the compression side.
Now the motor is tore down this far. What to do?
Options
1, get a gasket kit for the exhaust, put it all back together and run it.
2, get a gasket kit for the exhaust, put it all back together and sell it, then look for another motor.
3, Get an entire gasket kit, needed pistons and rings (if available) Hone or bore, then keep and run it.
I already have $1500 in it. I would be leaning toward options 2 or 3 as I would be upset if I just ran it and it destroyed itself soon. What do you all think?
07-08-2023, 11:27 AM #5
Screaming And Flying!
- Dec 2001
- 9,501
- 271
- 191
- 1979
3 1.....THEN GO HAVE FUNN....#2.... NO RESALE VALUE....# 3 BEING A 1979 SMALL PORT MOTOR....NA.....sorry I didn't know the caps were on.....
07-08-2023, 05:41 PM #6
5000 RPM
- Mar 2023
- SW Florida
- 484
- 29
- 79
from what i hear you can unbolt the rods and pull the crank just like the other merc inline motors. makes dealing with 1 recalcitrant hole less daunting.
07-08-2023, 08:21 PM #7
07-08-2023, 08:22 PM #8
Brought a pic for ya all.
Top piston (Right one in photo) has quite the gouge. Picture makes it look way larger than looking at it by eye. but maybe thats because I dont have my readers on my face when im looking at it in the garage. Number 2 has some gouging and looks like a brass color on the skirt when rotating the motor to see it. The other pistons look pretty darn good from what I can see through the exhaust ports.
07-09-2023, 01:28 AM #9
- Dec 2001
- 9,501
- 271
- 191
- 1979
I have a rebuilt 115.....that was a nice clean motor.......in my shop for 20 years......tor sale.......$ 400 ........drop on.......
07-09-2023, 07:32 AM #10
Mercury Tech: Promax water intrusion
By roadkill636 in forum Technical DiscussionReplies: 7Last Post: 05-01-2020, 09:17 PM -
Merc inline 1150 Rough idle, low comp and water intrusion?
By kswiatk in forum Technical DiscussionReplies: 5Last Post: 06-18-2019, 06:44 AM -
3.0/3.2 Sportmaster Gearcase Water Intrusion Fix
By Rayzor in forum General Boating DiscussionReplies: 29Last Post: 12-17-2015, 06:36 AM -
Mercury Tech: Water intrusion in #2, 4 and 6
By Markus in forum Technical DiscussionReplies: 10Last Post: 07-06-2008, 10:50 AM -
Water intrusion I6
By baldad45 in forum Technical DiscussionReplies: 4Last Post: 09-07-2006, 06:50 PM
