Results 1 to 12 of 12
Thread: Air injector O ring replacement
06-06-2023, 04:32 PM #1
Member
- Jul 2020
- Connecticut
- 30
06-06-2023, 05:01 PM #2
Screaming And Flying!
- 15,137
- 416
- 1479
- 6114
- 11813
yep. remove nuts and CAREFULLY remove the whole assembly. If ones toast the others may be. Trick for reinstalling them is to compress the stem and o-rings with a pc of hose from a teleflex steering fill hose, or similar. Lube it up with 2 stroke and slide hose over stem and let sit for a few hrs., then it will slide right in.
06-06-2023, 05:23 PM #3
Member
- Jul 2020
- Connecticut
- 30
06-06-2023, 06:34 PM #4
- 15,137
- 416
- 1479
- 6114
- 11813
The teflon ring has to be warmed in hot water to make it stretch a little. Unless there is an apparant problem with them, I just let em be. They seem fairly durable.
06-06-2023, 07:16 PM #5
Which o-rings are in question here? The ones on the air injector? Leave those teflon seals alone unless you've got one damaged, they are a complete pain to deal with.
www.InjectorService.com
Call/Text - 204-326-0390
XstreamVking liked this post
06-06-2023, 07:21 PM #6
Member
- Jul 2020
- Connecticut
- 30
06-06-2023, 07:27 PM #7
- 15,137
- 416
- 1479
- 6114
- 11813
I'm not a tech, I just work on my own optl's. I like helping out others to save money and time. And you are very welcome edgewater. Injector service is the opti x-pert here, he knows them inside and out.
InjectorService liked this post
06-07-2023, 03:10 PM #8
Member
- Jul 2020
- Connecticut
- 30
The one I need to replace shows when you pull off for the fuel rail by removing the two nuts. It’s a light brown color and I believe the part number is 804529.
I wasn’t sure if the Teflon seal breaks when I remove the fuel rail. I have no plans I removing anything else. Just pull the rail and whatever hoses need to be detached to the rail. Replace the plug. Gently slide the rails back in with some DFI oil on everything. Then hoses and nuts back on. Someone mentioned a Teflon seal so I figured I’d ask about it.
thanks for the help.
06-07-2023, 03:45 PM #9
That part number would be on the fuel injectors smaller o-ring. I just looked it up, what merc wants for these things is quite a lot. Do you have an injector shop near you? You in a rush? If not Ill send you 6 free of charge.
#11 On This Diagram
The teflon seals would be on the air or direct injector which is not pictured here.
06-07-2023, 03:54 PM #10
Member
- Jul 2020
- Connecticut
- 30
that’s really nice of you. I agree 100% I couldn’t believe they’re cost. Also needed to wait a up to week for delivery. I don’t know of a shop close by here in CT.
I ended up ordering from here since a buddy of mine was happy with the quality off Amazon - Brand fits Fuel Injector Filter Rebuild Kit for Mercury Optimax & Sport Jet Engines - https://a.co/d/diQg9Bs
If I should be nervous about using something like these I’d be happy to send you a fedex label for your offer if you email me at [email protected]. I can have fedex come pick them up from you when they’re ready.
06-07-2023, 03:57 PM #11
Ill gladly send some if you like, however chances are you are good to use the ones you found. The ones pictured are Viton (as long as they really are what they are advertising). I use Viton for all of my o-rings.
NICE PAIR liked this post
06-07-2023, 04:37 PM #12
Member
- Jul 2020
- Connecticut
- 30
Pink Tip injector replacement
By nightbasser in forum Technical DiscussionReplies: 0Last Post: 08-11-2018, 01:50 PM -
Opti injector open fault. Injector/cylinder fine
By RSWORDS in forum Four Stroke and Direct Injected Two Stroke EnginesReplies: 6Last Post: 11-03-2017, 11:01 AM -
Leaking Fuel Injector hose from rail. Need to replace injector?
By nburgart in forum Technical DiscussionReplies: 6Last Post: 08-26-2014, 12:57 AM -
3.0L Merc - Ring replacement on the boat?
By Clams Canino in forum Technical DiscussionReplies: 0Last Post: 01-12-2007, 02:34 PM
