    Fond du Lac WI
    We had a roof full of these at Plant 4 over the crank grinders/block line, etc. When the ill fated Lamb piston line went in, they were over it also. We had problems on certain days holding sizes, especially ballizing the piston pin bores. The machine would go out of tolerance for awhile and then be back, mind you, we were dealing in 10,000th of an inch on pin bores.
    Drove inspection and the setup men nuts! Then someone noticed as the sun passed over the skylights, it fell right on the machinery and warmed everything up! Just enough to throw pinbores out of whack! A couple cans of Merc Phantom Black over the skylights and we solved our problem.
  2. Thanks Lake X Kid thanked for this post
  3. #26702
    45 Post(s)
    A Great Merc Process Story
    Quote Originally Posted by bernie View Post
    Great story!!! We had a problem with some B2 fuselage pieces once. The machine beds were built atop some tidal mud flats in Seattle. The machining would be "off" at certain times of the day. It turned out to be "tidal pull" from the nearby Duwamish river. Thermals cause problems for everybody. Bridges, airplanes, you name it!
  4. #26703
    ...rare kiekhaefer mercury outboards flasher sign...
  5. Likes doug7488 liked this post
  6. #26704
    ...good story bern. mercury phantom black...the universal anecdote...
  7. #26705
  9. Likes Old boy, Lake X Kid liked this post
  10. #26707
    Southern California
    30 Post(s)
    "Just enough to throw pinbores out of whack" and thermal differences causing B2 fuselage out of tolerance.
    Another reason why, I am still in awe, of HOT-internal combustion engines lasting as long as some of them do.
  12. #26709
    Oct 2021
    Bradenton, FL
    Quote Originally Posted by WaterZebra View Post
    Were you given the opportunity to pass on your knowledge and experience to your successors, or did they even care?
    The smart new guys will pick your brain, most won't. They think they already know it all. That's why most are just parts changers. You can really learn from old guys that have been there
  13. Likes Mugs914 liked this post
  14. #26710
    45 Post(s)
    How?
    I never owned a Twister and didn't bother to ask those that did but how in the heck was the port side of the cowl attached where it clears the exhaust log?
  15. #26711
    Jan 2003
    BRISTOL, FL
    pretty simple. where the top and lower cowl ended,4 screws held 2 metal strips that were bolted vertically and where the wrap ends was folded to catch the 2 strips.
    The "Wheel Man" of the Sunshine Syndicate
  16. Likes GrewuponLakeX liked this post
  17. #26712
    Aug 2004
    20 Post(s)
    Mercury Twister Power placemat
Name:	Merc twister placemat .jpg
  18. Likes peterse90 liked this post
  19. #26713
    ...cool...
  20. #26714
Page 1781 of 1890 FirstFirst ... 781 1281 1681 1731 1757 1758 1759 1760 1761 1762 1763 1764 1765 1766 1767 1768 1769 1770 1771 1772 1773 1774 1775 1776 1777 1778 1779 1780 1781 1782 1783 1784 1785 1786 1787 1788 1789 1790 1791 1792 1793 1794 1795 1796 1797 1798 1799 1800 1801 1802 1803 1804 1805 1831 1881 ... LastLast
