Results 1 to 15 of 17
11-28-2022, 06:34 PM #1
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
2.0/2.4 bleed/Check valves, one snapped off
Two questions:
1) I think I read somewhere here that all the ones not in the block are check
valves and the ones in the block are just two way fittings? Or do I have that backwards? Or are they mixed where some on block and some not?
2) the one on the bottom of the block facing forward 1990 2.4/200 got snapped off clean. I need to extract the stub and put in a new one but I’ve never done it and don’t know where to get one.
Just finished skimming through the manual for the 1990 2.4/200 and it doesn’t show the fitting on the bottom of the block for the carb version, but does show for one of the EFI versions. This 1990 2.4/200 block is being used with 1983 2.4/200 “dressing”. So it’s possible that the previous owner replaced his 1983 2.4 block with an EFI block 1990 2.4/200?
Anyway the manual is pretty thin on details about how to handle these bleed fittings.
-Peter"padded wonder"
__________
the wet:
18’ Bahner bow rider, 2.4/200
the dry:
2003 bmw ///M5
and a handful of clunkers
11-28-2022, 11:19 PM #2
I have seen people post about having some still available. I can take a picture of my 1990 V200 carb motor and post my plumbing if you need it
pcrussell50 thanked for this post
pcrussell50 liked this post
11-29-2022, 12:10 AM #3
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Yes, please.
Originally Posted by rgsauger;[URL="tel:3369524"
Also, I re checked my 1990 manual. The fuelie XRI block has two bleed/check fittings that the carb block doesn’t have: one on the bottom front of the block and one on top. They are connected to each other. The carb blocks don’t have those two. My carb motor appears to have been built out of an XRI fuelie block. And it’s the bottom fitting that I broke off. And I don’t know if it’s a check or an open. And I don’t know any hot tips on how to dig it out, just that it’s a press fit. Or what sealer to use if I find a used one to press back in.
__________
the wet:
the dry:
2003 bmw ///M5
11-29-2022, 12:56 AM #4
Is your motor put together or is it torn apart right now? I can get those pictures and post them up tomorrow, Tuesday.
11-29-2022, 12:59 AM #5
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Motor is together right now, but I will be taking off the intake to put on CCMS reeds and check out the carbs for peace of mind, even though I know it runs
Originally Posted by rgsauger;[URL="tel:3369529"
as is."padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
11-29-2022, 03:36 AM #6
"one on the bottom front of the block and one on top. They are connected to each other. The carb blocks don’t have those two"
check again.. they all have one bottom to top... only way ta oil top bearing.. one on top is open (will flow either way) one on bottom is one way (flows out or up only, very important).... they all have it that way... ya need ta know that when ya replace either bleed valve.. all horizontal front motors have it that way...
3 to 4
7 to 10Last edited by tlwjkw; 11-29-2022 at 04:10 AM.
11-29-2022, 07:43 AM #7
I think I may have some in the shop. I will check later. Do not run motor till fixed.
RockTeam Junk
11-29-2022, 10:20 AM #8
The Historic Photo Master
- Jan 2004
- Florida
- 38,615
- 78
- 1787
- 385
- 20596
- 5 Post(s)
...note to self: never scrap a junk block without first stripping it of all bleeder fittings...
11-29-2022, 12:45 PM #9
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Damn! You guys are worth your weight in gold. The !@#$%^&* Mercury manual is highly misleading on this.
It's clearly there in the fuelie diagram:
But not on the port side diagram of the carb motor. (This is what confused me):
But here it is on the carb motor on the starboard side. (This is the part I missed):
Big thanks to all involved who already knew how important this was.
Questions:
-Any tips on digging out the broken fitting on the bottom?
-Should I put any certain sealer on the replacement fitting (if I can find one), before I press it in?
-PeterLast edited by pcrussell50; 11-29-2022 at 12:56 PM.
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
11-29-2022, 03:04 PM #10
OK Peter I finally found the box of fittings. Is yours threaded or pressed. All I could find, for now, with check valves are threaded. If yours is threaded pm your address and I will get one mailed out.
RockTeam Junk
11-29-2022, 03:11 PM #11
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
11-30-2022, 01:43 PM #12
11-30-2022, 06:06 PM #13
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Most likely. It’s a 1990 carb 2.4/200. This is what I get off Crowley: https://www.crowleymarine.com/mercur...82-check-valve Looks pretty much the same. Thanks a ton. PM me for how much.
Also, since you’re a mechanic, any tips on digging out the old one? It snapped off flush. And any sealer needed or just the red stuff that come on it?
__________
the wet:
the dry:
2003 bmw ///M5
11-30-2022, 07:35 PM #14
Yeah thats the same check valve at crowley. They are pretty much one time use; they compress when you put them in. So they never fit right in my opinion when you use used ones. If you DO use used ones, I use the green Loctite bearing and seal retainer: they stay in. When you have new ones the red stuff is sufficient sealant and they compress tight when they go in, so just send them in straight out of the package. I drive them with a super small 1/4" drive deep socket, something like 3 or 4 mm that just fits over the barb.
Pulling the broke off one out should not be hard. Screw a small wood screw into the core of it and then gently wobble and pull it out with vise-grips, pliers or dikes. The biggest thing you have to be aware of is not to crack the aluminum where its pressed into. Depending on where it is in the engine there can be a very small wall of aluminum adjacent to it (like on the intake manifold). Make sure the new check valve checks the same way as the old one was supposed to, obviously.
If all else fails and the press-in area gets hogged out to where it wont hold a new fitting tight then I have drilled and tapped them to take the later thread-in check valves. But hopefully you won't have to do that.
11-30-2022, 08:34 PM #15
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
Solid gold, mate. Love this place.
__________
the wet:
the dry:
2003 bmw ///M5
Mercury Tech: 2.0L bleed check valves
By pcrussell50 in forum Technical DiscussionReplies: 2Last Post: 01-08-2017, 03:47 PM -
Bleed system check valves
By 300Procraft in forum Technical DiscussionReplies: 0Last Post: 01-29-2011, 03:40 PM -
Mercury Tech: Bleed Check Valves/96 250 EFI
By Liberator*21 in forum Technical DiscussionReplies: 2Last Post: 04-24-2010, 04:06 PM -
bleed line check valves
By dadgumit in forum Technical DiscussionReplies: 6Last Post: 01-31-2009, 09:27 AM -
2.4L Bleed Hose Check Valves
By Roger Steele in forum Technical DiscussionReplies: 7Last Post: 11-25-2004, 02:33 PM
