Results 1 to 9 of 9
    I live in Prineville Oregon which is in the central part of the state
    Lithium battery on a 260 without voltage rectifier
    Will not having a voltage regulator on a 16amp system damage a lithium battery or should I just stay with a lead acid battery.
    Many thanks, Carter
    Gravenhurst, Ontario.
    Be very careful!!
    We ran an Antigravity lithium battery on my son’s modified Yami 90.
    It turned 7500-8000 and after a prolonged run down the lake at high RPM the battery caught fire…..this is why you carry a fire extinguisher!!
    I thought it may have been defective. Cleaned everything up and swapped in an extra Volt Freak I had on the shelf. After a few more rips up & down the lake he came back and said his trim wasn’t working…….nothing was working……no hydro……
    Volt Freaks have an automatic shut off….. if they get overloaded or detect excess voltage they shut off.
    Turned the battery back on & he was back in business.
    As it turns out, at excessively high rpm the Yami produces a lot of juice….enough to spark up an unprotected lithium battery.
    If you’re going to run a lithium battery I’d suggest you have a good voltage reg to dump excess voltage and / or run a battery with overload protection.
    Or you could run a good ol’ lead / acid battery……when in doubt, keep it simple….����*♂️
  3. Thanks rgsauger thanked for this post
    What he said.
  5. Likes OnPad liked this post
    SOCAL, the land of 75* and sunny!
    Quote Originally Posted by Carter Powell View Post
    Many thanks, Carter
    Curious, why aren't you running a rectifier? At any rate, if you want to go lithium, get a hold of the people at EarthX. They have a good protection system on their batteries. I run their batteries on everything I own. My motorcycle sat over a year, and the battery lost .1 volt
    Quote Originally Posted by John S View Post
    He said voltage regulator, not rectifier... battery won't charge at all without a rectifier.
    Feb 2011
    HUDSON, FLORIDA
    i run a lith batt on my 96 pmax, stock motor, been running fine 2 yrs. batt says charge 10a max.
    May 2009
    7 Post(s)
    Many thanks, Carter
    Yes or no.
    You should never run a LiFePO4 battery without a BMS. The BMS, as long as it works right, will take the battery offline before you burn up your boat. You may be stranded if that is the only battery in your boat. This is less likely to happen if you have a properly functioning regulator. It’s always better not force the BMS to take drastic action.
    I hear you can buy LiFePO4 batteries without BMS. Too risky for me.
    So get a GOOD regulator before you go with lithium iron phosphate … or stick with lead acid.
    -Peter
    "padded wonder"
    __________
    the wet:
    18’ Bahner bow rider, 2.4/200
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
    Jul 2021
    Pompano Beach
    I wouldn't do it. Without a regulator, if the BMS shuts off due to the lithium being fully charged, I have a feeling you're going to be burning up electrical components on your motor when the amperage has nowhere to go.
  11. Thanks pcrussell50 thanked for this post
    Likes pcrussell50, 25two.stroke, John S liked this post
    Sep 2008
    Dow, IL \ Theodosia Mo.
    Lead acid for the 260. Ive had nothing but problems with other types.
  13. Thanks pcrussell50 thanked for this post
    Likes pcrussell50, scott reierson, Charli liked this post
  1. Lithium battery suppliers?
    By Will hedrick in forum General Boating Discussion
    Last Post: 01-17-2022, 07:09 AM
  2. Going out testing a Harley lithium battery on a 300xs
    By Pachanga_rick in forum General Boating Discussion
    Last Post: 09-08-2017, 09:21 AM
  3. Mercury Tech: How much juice needed to power 200xs / Lithium Battery question.
    By Pachanga_rick in forum Technical Discussion
    Last Post: 06-18-2015, 04:43 PM
  4. lithium battery charger
    By bullwhipjkg in forum Misc. Parts and Accessories
    Last Post: 12-11-2014, 08:23 PM
