Results 1 to 14 of 14
Thread: 1981 mercury 225 bleed lines
02-25-2022, 12:09 PM #1
Junior Member
- Jan 2017
- Minooka
- 16
Does anyone have good pictures or a better drawing of bleed line routing on a 1981 mercry 225 than the mercury manual. Thanks in advance.
02-25-2022, 03:03 PM #2
rgsauger thanked for this post
02-25-2022, 08:57 PM #3
Junior Member
- Jan 2017
- Minooka
- 16
02-26-2022, 06:54 AM #4
6000 RPM
- Feb 2002
- Cudjoe Key FL
- 1,621
- 69
- 585
- 3904
- 5590
Do a search here. Chris Carson just answered this question within the past month.
02-26-2022, 12:27 PM #5
03-06-2022, 12:01 PM #6
Junior Member
- Jan 2017
- Minooka
- 16
Thanks guys but those are all different. The closest thing I can find is this https://www.screamandfly.com/showthr...lse-pump-setup
03-06-2022, 12:22 PM #7
Junior Member
- Jan 2017
- Minooka
- 16
This is my mercury book picture as well
03-06-2022, 03:13 PM #8
think he's got a total of 12 bleed bids (not countin' tha "oiler" bibs) on tha front of tha motor?. ya gotta use 6 T's".. this was used outta hi perf.. called one on those "special names" like formula or something?.. don't remember for sure?.. if ya look at tha ones posted (dia.)and look long n hard at what ya got you should be able ta figure it out.. tryin' ta put inta words would only get ya more confused i think.. GL.
Matt84vector thanked for this post
03-06-2022, 03:37 PM #9
The Historic Photo Master
- Jan 2004
- Florida
- 38,706
- 78
- 1773
- 384
- 20450
- 4 Post(s)
03-07-2022, 04:57 AM #10
07-30-2022, 11:09 AM #11
Member
- Dec 2021
- NV
- 45
- 9
- 9
- 26
FYI, I have my 1985 2.4L engine disassembled (original, no apparent previous disassembly). My bypass routing is slightly different. There is not a fitting on cylinder #3, only 1, 5, 2, 4,& 6. There is also not a fitting for a bypass hose between upper and lower bearings. Inspection of the front block half reveals lube holes in the bearing surfaces leading to a channel on the Reed side of the reed block. I have mapped the hose routing on my engine which does not perfectly match any manual I can find (see diagram). This is a vertical reed engine. Provided in case someone is looking at a similar engine.
pcrussell50 thanked for this post
pcrussell50 liked this post
07-30-2022, 02:11 PM #12
Team Member
- May 2009
- 2,294
- 704
- 135
- 917
- 518
- 7 Post(s)
G'day Bill
That looks like a vertical reed setup like on my 2.0l (the one with two tired cylinders). And thus it looks like a 5-line bleed setup too. Also like the one on my 2.0l.
(For some reason, I thought all 2.4's were horizontal reed setups.)
-Peter"padded wonder"
__________
the wet:
18’ Bahner bow rider, 2.4/200
the dry:
2003 bmw ///M5
and a handful of clunkers
07-30-2022, 05:52 PM #13
07-30-2022, 06:05 PM #14
Member
- Dec 2021
- NV
- 45
- 9
- 9
- 26
To be exact, my block is dated December 84 and is an 84 motor per Mercury. The boat is an 85 which I just use 85 overall when talking about it in general.
Bleed off lines and Enrichment lines
By Krazymaan in forum Technical DiscussionReplies: 11Last Post: 01-25-2025, 11:34 PM -
Colored bleed lines and water dump lines
By DaveR in forum General Boating DiscussionReplies: 25Last Post: 01-25-2025, 08:06 PM -
Best tubing for bleed lines/small fuel lines 2.4 MERC
By rujr in forum Technical DiscussionReplies: 28Last Post: 01-18-2025, 12:45 AM -
Mercury Tech: 1981 Bridgeport 225 Bleed lines
By MaMikee in forum Technical DiscussionReplies: 6Last Post: 05-02-2021, 10:57 AM -
Mercury 3 Liter EFI, ECU, and bleed lines
By rdoaner in forum Technical DiscussionReplies: 4Last Post: 02-26-2021, 08:58 AM
