Page 3 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 31 to 45 of 96
  1. #31
    Jun 2022
    Tn
    If I remember there were two different tps used on lazer motors that had different voltage readings.
    If you are sure your motor should be getting 7.4 v @ WOT and it is only getting about half that then there is definitely a problem and that would cause all sorts of lack of power. Good thing to do would be find someone with a digital ecu and a ddt to read it and plug it in and look through all the parameters to see if anything is way off
    The manual I知 using is for 150 efi serial 0Dxxxxx and up
    My serial is 0g061997
    Unfortunately all the service places in my area are booked months out as I知 sure is the case all over , and no one I know has any test equipment
  2. Likes OnPad liked this post
  3. #32
    Jun 2022
    Tn
    Quote Originally Posted by OnPad View Post
    Your fuel pressure is fine with a pump mounted inside the vst. I wasn't paying attention again!
    Sounds like you have a good handle on the situation.
    Make sure your trigger isn't binding up, high speed timing bolt should be hitting the stop.
    My pump is outside the vst maybe I知 missing something
    I can move the trigger through its full range by hand
    thanks again for all the replies I知 sure I値l get it sorted eventually lol
  4. Likes OnPad liked this post
  5. #33
    Nov 2021
    Northwest
    My 97 supermag is mounted inside. My 95 200 is external.
    Check out Ronnie's post if external 36-39psi.
    Your hot on the trail.
    Hope you don't have to buy a tps, last I heard they don't give them away, $$$ if you can find one.
  6. #34
    Jun 2022
    Tn
    The TPS is very expensive but, cheaper than the ECU/ACU lol
    Im not opposed to spending money, as it sits right now the boat is useless soooooo I have to fix it lol
  7. Likes OnPad liked this post
  8. #35
    Jun 2022
    Tn
    I will also add that the last water testing was performed both with and without the idle stabilizer hooked up.
    I’ve read elsewhere that that box can cause problems when it fails (obviously not my problem currently) but what is the general consensus here? Remove ? Leave it?
  9. Likes OnPad liked this post
  10. #36
    Nov 2021
    Northwest
    I have mine removed, without any negative consequences.
    Some people like to leave em on.
  11. #37
    Jan 2020
    Pittsburg, Ca
    Check all your fuel filters. Theres like 4 in that engine. One in the J hose under the vst, one big green one inside a metal round housing in the upper forward port side of the engine. Also I have seen those pumps fail...pumping just fine at idle and then as soon as it gets up to 2000 or so the pressure drops off to 20 lbs and motor runs like ass. Make sure your fuel pressure is good and then check into the tps for sure.
    You are using the correct manual for that engine.
  12. Likes OnPad liked this post
  13. #38
    Jun 2022
    Tn
    Did your timing need to be reset after removal?
  14. #39
    Jun 2022
    Tn
    All fuel filters have been checked/cleaned/replaced
    even the screens at the injectors
    Fuel pressure is 34-36 psi at idle and also while trying to accelerate (which is the problem I’m having)
  15. #40
    Nov 2021
    Northwest
    I did reset my timing. I don't recall it messing up my idle timing to much but was only getting 19ー up top, had to bump that up to 24ー or 25ー.
  16. #41
    Jan 2020
    Pittsburg, Ca
    I always check the timing after I take them off. And I always take them off. Sometimes the timing is no different with them off and sometimes its way off.
    I would be suspect of your tps next...I'm sure someone has a good used one you can get a hold of.
  17. Likes OnPad, rgsauger liked this post
  18. #42
    Nov 2021
    Northwest
    I probably don't recall it changing at idle, cause I don't use a light for idle, I just set so it doesn't die, usually the trigger barrel ends up almost splitting the case halves.
ID:	505763Click image for larger version.
  19. #43
    Apr 2017
    pa
    5 Post(s)
    I have a lot of parts lying around for those motors. I dont know much about the efi systems because I run carbs. Send me a pic or part number of the TPS and I can send you one
  20. Likes OnPad liked this post
  21. #44
    Jun 2022
    Tn
    Quote Originally Posted by bullet123 View Post
    Thanks for the offer but I ruled out the TPS
    turns out my wire workaround for the test harness was causing inaccurate readings
    I am now able to get the full range of voltage
  22. #45
    Nov 2021
    Northwest
    Stuff to consider.
    Check spark.
    Retest electrical components. Bias, kill circuit, voltage regulators, s. box in and out, coils, trigger.
    Leaking injectors.
    Fuel pressure regulator.
    Pulse pump leaking fuel back to engine.
    Reed valves broken.
    Check valve, or obstruction in fuel tank.
    Set timing, checking on all cylinders. Could have defective flywheel.
    Lower unit trying to seize.
  1. hard to start
    By brokeboater in forum Technical Discussion
    Last Post: 12-22-2019, 09:29 PM
  2. Mercury Tech: 2000 mercury 200 efi hard cold start
    By ICEBERG8 in forum Technical Discussion
    Last Post: 07-02-2018, 02:13 PM
  3. Hard Start
    By herk91 in forum Technical Discussion
    Last Post: 10-18-2012, 12:34 PM
  4. Rebuilt a Mercury 115 HP and is now hard to start.
    By ronnyd8719 in forum Technical Discussion
    Last Post: 01-09-2007, 06:53 AM
  5. 150 EFI Hard to Start
    By whays in forum Technical Discussion
    Last Post: 11-29-2005, 12:35 AM
