Page 31 of 34 FirstFirst ... 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 LastLast
Results 451 to 465 of 501
  1. #451
    12 Post(s)
    Agreed.
    I followed IMSA car road racing in the ‘80’s and Mazda ruled GTU which is Grand Touring Under 3.0 liters.
    Many competitors complained that Mazda was given an unfair, +50% displacement capacity due to the unfair way a rotary was classified.
    Love the motors and tech but please…..
    Quote Originally Posted by Lake X Kid View Post
    How do you quantify cubic-inches/liters for a Rotary engine?
    A) One rotor has 3 combustion surfaces/heads. Therefore, (per each rotor) 3 x combustion chamber area = cubic-inches/liters.
    B) One rotor/combustion chamber. Therefore, each rotor is only designated as only having 1 combustion head. 1 x combustion chamber area = cubic-inches/liters.
    I am wrong to think the rotor engine should be classified as example A. Giving the rotor engine & the conventional combustion piston engine equal footing in engine size comparison.
    Example B, seems to me, to give the rotary engine an unfair advantage in racing classification against piston engines.
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  2. #452
    Jun 2009
    Georgia
    44 Post(s)
    At the time of the rotary race engine, they were competing against 2 strokes. A 2 stroke engine has one power pulse per crankshaft revolution; so does a rotary. A 2 stroke completes all phases, intake, compression, power and exhaust for each revolution of the crankshaft; so does a rotary. Thus if compared to a 2 stroke the displace should be measured for 1 revolution of the crank. It's the 4 stroke that's the oddball. It takes 2 complete revolution of the crank to complete all 4 phases. I don't recall anyone ever saying a 2 stroke should be measured for 2 crank revolutions as a 4 stroke. A 4 stroke displacement has always been measured displaced volume per crank revolution, same as a 2 stroke and a rotary. The argument only comes up when the rotary dominates. Kinda like Andy Granitily's turbine. Kinda like when the big boys banned the 2 stroke in thunder boat racing. The establishment hates being beat. Enough for tonight, I'm going to the shower and bed.
  3. Likes Bob V, Instigator liked this post
  4. #453
    South Florida
    I count 3 ignition events per crank revolution. One for each rotor face. Thus the total swept volume of all 3 faces equals displacement. Seems like basic trig to me?
  5. #454
    Jun 2009
    Georgia
    44 Post(s)
    Quote Originally Posted by 2us70 View Post
    You don't count too well. The rotor turns at 1/3 the speed of the crank. There is ONLY ONE spark plug fire for each rotation of the crank.
    Wankel animation - YouTube
  6. Thanks lars strom thanked for this post
    Likes lars strom liked this post
  7. #455
    Apr 2006
    United Kingdom
    Remind me not to ask you to balance my cheque book.
  8. #456
    Apr 2006
    United Kingdom
    Next thing John somebody will mention the usual.
    Ha, looks like you beat me to the punch. I'm getting slow.
  9. Likes willabee liked this post
  10. #457
    Southern California
    30 Post(s)
    Quote Originally Posted by Rotary John View Post
    That clarifies a lot, thanks RJ.
  11. #458
    Jun 2009
    Georgia
    44 Post(s)
    The real difference in the rotary is each of the 4 cycles consumes approx 270 degrees of crank rotation. A 2 stroke by contrast consumes approx. 90 degrees for each cycle and a 4 stroke approx 180 degrees. ( forget about overlap and exact port timing). This is the reason the rotary has such high power density. Displace ment is measured max volume - min. volume x the number of cylinders or rotors. I you want equality give a fixed amount of fuel and run what you brung. Audi did that with their turbo diesels.
  12. Thanks powerabout thanked for this post
    Likes Instigator liked this post
  13. #459
    Jun 2009
    Georgia
    44 Post(s)
    Quote Originally Posted by techteam View Post
    James: I'm surprised Jackie hasn't jumped in and claim it should be 8 times because he raced a V-8 four stroke.
  14. Thanks lars strom thanked for this post
    Likes lars strom, powerabout, techteam liked this post
  15. #460
    12 Post(s)
    Not that I matter in this equation but…, I still don’t get it John.
    4 stroke to two, I do.
    Rotary to everything else, I still don’t.
    One crankshaft revolution what do we have correct?
  16. #461
    Jun 2009
    Georgia
    44 Post(s)
    One crankshaft revolution: One spark plug fire, one power stroke. one intake, one compression, one exhaust; just like a 2 stroke. The difference is these events happed simultaneously in a rotary, while they happen sequentially in a 2 stroke. You have to also remember the rotary is a 4 cycle. It has a positive exhaust cycle where a 2 stroke exhaust is dependent on blow down and the incoming fresh charge to force the spent charge out the exhaust port. Same is true for the rotary intake, compression and power cycles.
  17. #462
    I think were the punters get confused is which part is counted as a revolution?
    See above for crank as explained by John.
  18. #463
    South Florida
    So the crankshaft in overdriven 3 to 1 from the rotor? Does this have an effect on torque at the crankshaft output end? Also what are the revs seen by both the rotor and crank in operation? My only experience with a rotary was driving my brother-inlaw's Mazda RX-3 many years ago.
  19. #464
    Jun 2009
    Georgia
    44 Post(s)
    You have said it correctly but should read the rotor turns at 1/3 crank RPM. The torque on the crank is determined by the eccentric of the shaft and the combustion pressure on the rotor and is independent of the rotor RPM. However, because the shaft has to turn approx. 270 Degrees before the exhaust port opens, the force on the eccentric lasts longer than a piston engine. Hope this makes sense.
    The OMC race engine ran between 7000/8000 RPM crankshaft meaning the rotor turned 1/3 of that; 2333/2667 RPM. Before someone asks again, the final version of the race engine produced between 265/280 prop shaft HP at those RPM's. (1974)
  20. Thanks powerabout thanked for this post
  21. #465
    Southern California
    30 Post(s)
    The rotor engine’s rotational components seem to be more conducive to generating crankshaft rotation, then the action of converting piston’s linear motion into crankshaft rotation. High RPMs would seem not to be a major obstacle (in spite of an eccentric non-circular rotor motion, and the rotor’s larger circumference turning the smaller diameter crankshaft should supply ample torque.
    However, being the rotor engine has a more favorable geometry of internal moving parts, why does it not dominate the boat & car market? Is the rotor engine’s weak link(s) due to … cooling issues, seal problems, combustion efficiency – in comparison to piston engines, or …?
