Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Thread: 260 Rings$$$
    Aug 2017
    Grand Cayman
    I’d just bite the bullet and buy a set of the Gold Ti Nitrate rings. Nic bore 2.5s are getting harder to come by and hanging a piston in the bore at high RPM due to a cheap ring breaking or sticking will make a nice window in your block. Don’t ask how I know. I see Powers has them for $599, which is a lot, but a lot less than replacing/repairing your powerhead.
  2. Likes Stoker boy liked this post
  3. #17
    Mar 2004
    Brooklyn Park, MN
    you may want to check with Dean at Wizard too, his pistons use merc rings. Is this what your talking about with a stuck piston in an expensive nik block? haha check out number 4!
Name:	280 pistons in block.jpg
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. Likes CI STV liked this post
  5. #18
    Apr 2020
    South Carolina
    John Marles has sets Chromoly rings that apparantly last just a long as gold rings and does not hurt the nic. He said he has seen no issues with them. $200 shipped for 12 rings. Probably Ti coated.
  6. Thanks CI STV thanked for this post
  7. #19
    Aug 2017
    Grand Cayman
    Quote Originally Posted by Qshot1989 View Post
    Thanks. Good to know. That guy really knows his sh!t, so if he says it works, I would take his advice.
  8. #20
    Aug 2017
    Grand Cayman
    o
    That looks good to what I did to my first 260 years ago. It stuck the piston so hard that it broke the crank, the rod snapped and windowed the block so bad you could stand on one side and read a newspaper on the other!
  9. Likes rjdubiel liked this post
  10. #21
    Big Rock, IL / Eagle River, WI
    These are the rings I have been referring to, they are black oxide coated.
  11. Likes Qshot1989 liked this post
  12. #22
    I'm leaning towards staying with the gold rings. John said the black oxide rings would last 100 hours...does that mean they need to be replaced somewhere around 80-90?
    I know the gold rings will go at least 120 hrs. It's worth the money to me for another 30-40 hours of life. Not to mention the cost of gaskets and seals to do a re-ring.
    jmo
  13. Likes stoneman liked this post
  1. Mercury Tech: 280 ros rings
    By 1750Bullet in forum Technical Discussion
    Last Post: 04-11-2012, 09:35 PM
  2. rings?
    By tlwjkw in forum Technical Discussion
    Last Post: 03-24-2012, 06:18 PM
  3. 260 rings can i use chrome rings
    By jgiroux in forum Technical Discussion
    Last Post: 07-02-2009, 09:54 AM
  4. good rings - bad rings
    By roadkill636 in forum Technical Discussion
    Last Post: 04-02-2008, 05:25 PM
  5. piston rings & crank sealing rings
    By TB21 in forum Technical Discussion
    Last Post: 12-19-2001, 08:49 PM
