Results 1 to 6 of 6
04-30-2018, 04:59 PM #1Member
- Jul 2017
- Elk grove
- 31
Shutters on Mariner magnum 175 hp efi
After rebuilding my motor I was double checking all my link and sink, WOT those things. When setting the WOT I noticed my shutters weren’t open very fare maybe 1/4 of the way, then I noticed the screw that sets it was in almost all the way. Shouldn’t all 3 be open on a 90 degrease @ WOT
05-01-2018, 10:48 AM #2Screaming And Flying!
- 14,753
- 381
- 1305
- 5603
- 11035
You sure that all is installed correctly? I would go back thru it and check all the parts carefully. It should open fairly close to 90 deg. Something is not installed correctly.
05-01-2018, 12:02 PM #3
Yes. The butterfly's or throttle plates will be 90* when fully open. They will only be 1/4 open at full timming advance then its all throttle plate movement after that.
05-02-2018, 08:03 PM #4Member
- Jul 2017
- Elk grove
- 31
When I put the throttle all the way dawn wide open they are only open 1/4 maybe than I noticed the the wot screw was almost set all the way in there is 1 3/4 of thread it can be adjusted. Thanks for the post nothing in the book goes over it.
08-20-2018, 06:09 PM #56000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,539
- 437
- 68
- 435
- 467
07-07-2021, 01:55 AM #6Member
- Apr 2021
- Californian
- 55
You have a set screw dawn in there. You need to line up the roller to your came you will see the lines they should be lined up with the throttle closed, write behind the fuel managment system you will see your a screw in middle of the 3 flys I beleive its 4 thousands clearance. You dont want your throttle fly to hit the stop because you take a chance of them getting stuck.
98 150 mariner 2.5 magnum 3
By knot<safe77 in forum Technical DiscussionReplies: 5Last Post: 10-12-2013, 04:17 AM -
Mariner Magnum VS Regular Mariner
By XstreamVking in forum Technical DiscussionReplies: 1Last Post: 09-02-2010, 07:08 PM -
Mariner 3,0 lit magnum EFI
By ae23 in forum Technical DiscussionReplies: 0Last Post: 02-17-2008, 03:08 PM -
Mariner 150 Magnum II
By MarkS1234 in forum Technical DiscussionReplies: 9Last Post: 02-26-2007, 06:16 PM -
150 johnson shutters
By CharlieB in forum Technical DiscussionReplies: 12Last Post: 08-20-2004, 09:04 AM
