Results 1 to 5 of 5
    Jul 2017
    Elk grove
    Shutters on Mariner magnum 175 hp efi
    After rebuilding my motor I was double checking all my link and sink, WOT those things. When setting the WOT I noticed my shutters weren’t open very fare maybe 1/4 of the way, then I noticed the screw that sets it was in almost all the way. Shouldn’t all 3 be open on a 90 degrease @ WOT
    You sure that all is installed correctly? I would go back thru it and check all the parts carefully. It should open fairly close to 90 deg. Something is not installed correctly.
    Yes. The butterfly's or throttle plates will be 90* when fully open. They will only be 1/4 open at full timming advance then its all throttle plate movement after that.
    Jul 2017
    Elk grove
    When I put the throttle all the way dawn wide open they are only open 1/4 maybe than I noticed the the wot screw was almost set all the way in there is 1 3/4 of thread it can be adjusted. Thanks for the post nothing in the book goes over it.
    Feb 2011
    HUDSON, FLORIDA
    Quote Originally Posted by roadkill636 View Post
    NOmatter what i do i cant get any butterfly movement untill full advance due to cam shape. all alignment marks are on. roller follows cam but does not rise until max timing. now i heard thats correct on laserefi?
  1. 98 150 mariner 2.5 magnum 3
    By knot<safe77 in forum Technical Discussion
    Last Post: 10-12-2013, 04:17 AM
  2. Mariner Magnum VS Regular Mariner
    By XstreamVking in forum Technical Discussion
    Last Post: 09-02-2010, 07:08 PM
  3. Mariner 3,0 lit magnum EFI
    By ae23 in forum Technical Discussion
    Last Post: 02-17-2008, 03:08 PM
  4. Mariner 150 Magnum II
    By MarkS1234 in forum Technical Discussion
    Last Post: 02-26-2007, 06:16 PM
  5. 150 johnson shutters
    By CharlieB in forum Technical Discussion
    Last Post: 08-20-2004, 09:04 AM
