Results 31 to 45 of 64
Thread: exhaust tuner
05-27-2021, 05:46 PM #31
Now Can we get back to the mans Original Question?
05-27-2021, 06:25 PM #32
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,653
- 301
- 279
- 1791
- 1275
My old 1750 really did change tone at 7700-7800 RPMS, really screamed from there up to probably 8200 (my 8k tach was pegged). That one was stuck on a later plate with a bad mismatch and a 2.4 200 bell tuner. The original cast in tuner on the 1750's is the same length and shape as the 2.5 200/225 promax tuner. I think that the stroke has more to do with tuner length and that mercury got it right the first time. JMO, but I run stock tuners (either the square 2.5 style with the holes plugged or the 2.5 200 bell) on all my junk. Works for me...
Josh Peterson
05-27-2021, 08:13 PM #33
Tuners just make money for those making them, show some real results ...
18 years ago a guy from up north John Lenskaw wrong spelling spent a lot of money and time building funky long tuned pipes to run a pro class in ODBA, all it did was make money for the welder.
How many RPMs do those Monty V-8s turn?
may as weld a garbage can on there same results, any outboard drag racer is over 6,000 rpm within 5 feet of crushing the peddle,
tuners are the most over rated mod.
nitro_rat liked this post
05-27-2021, 08:21 PM #34
05-28-2021, 05:22 AM #35Bud Conner "Heathen" "Defending Our Constitution"
05-28-2021, 05:51 AM #36
Reminds me of Lingenfelter who said a great cam in an engine with a not so great set of heads will be a not so great engine. But a great set of heads with a not so great cam will still be a great engine. If the tuner didn't do nuthin Merc wouldn't have put the big ones on the drag motors. The choke looks from my seat to be in the exh chest and porting first but once opened up the tuner becomes more of the strangler.
So without ever putting a grinder to a Merc motor or without ever changing a tuner myself it looks to me from the info in this thread to answer the OP it sounds like its not worth doing a tuner swap unless you do the motor mods first.Hydrostream dreamin
05-28-2021, 07:37 AM #37
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,653
- 301
- 279
- 1791
- 1275
if you look at a 225/260/280 base gasket compared to a 200 you'll see that the exhaust outlet is so much bigger on the "race" block that it's almost or actually in the water of the 200. That's the choke point, not the tuner. Big tuner on a fishing block is like running 3" duals on your mom's Malibu wagon with a stock 305. A 2-1/4" system would make the same or more power because the extra flow just isn't necessary...
Josh Peterson
LakeFever liked this post
05-28-2021, 07:49 AM #38'78 Hydrostream Viking/'98 225 ProMax
05-28-2021, 08:52 AM #39
05-28-2021, 09:12 AM #40
IIRC the differences between the 200efi FF block and the 225ProMax are; 5petal vs 7petal, bump in compression, computer tuning. I think thats it isn't everything else tuner/plate the same?
05-28-2021, 09:15 AM #41
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,653
- 301
- 279
- 1791
- 1275
Josh Peterson
05-28-2021, 09:22 AM #42
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,653
- 301
- 279
- 1791
- 1275
Just balanced, boyesen reeds, and 260 rod bearings. Otherwise it's a stock vertical front '79 175.
No, block is different, plate is different. You can't make any 200 block have the promax outlet without machining and welding. Jay Smith and I have discussed doing it but we haven't pulled the trigger yet due to the amount of welding that would be involved.Josh Peterson
05-28-2021, 09:29 AM #43
05-28-2021, 10:19 AM #44
05-28-2021, 10:28 AM #45
I already mentioned that previously. And described what needs to be done. And it included the blocks discharge opening. The problem I now see is (correct me if I’m wrong). Your motor is already together. So no work can safely be done to the chest or discharge. That’s why I mentioned that matching the adapter plate to the tuner wouldn’t accomplish anything. Because the block is still a choke point.
exhaust tuner
By dzalj1 in forum Technical DiscussionReplies: 2Last Post: 04-08-2007, 06:58 AM
