Page 8 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 106 to 120 of 250
  1. #106
    May 2020
ID:	483250 This is the epoxy I’m using, this stuff is really easy to work with now that I can control the temperature in my shop, it kicks nice and slow unlike in the summer when it was hot as hell it kicks much quicker. Food for thought for anyone thinking of using this stuff. It will also lighten your wallet up. I was gonna gel coat my stringers but now just planning on giving them a light sanding and then putting another coat of the epoxy on. This stuff cures to a glass finish and will do the same thing the gel would do.
  2. Likes LakeFever liked this post
  3. #107
    May 2020
ID:	483256 Drain holes drilled in stringer fingers and sealed with epoxy.
  4. Likes tnelsmn liked this post
  5. #108
    Quote Originally Posted by Jmr1974 View Post
    Epoxy resin should be more waterproof than gel coat anyway, and it eliminates any "poly over epoxy" issues.
  6. Likes XstreamVking liked this post
  7. #109
    May 2020
ID:	483330Click image for larger version.
ID:	483331 Things are moving along, next is to tab the floor in and glass over it all.
  8. #110
    May 2020
    Just finished tabbing the floor in. I used the squeeze bag method with thickened epoxy for the fillets and it worked like a charm. Next I need to get a new block up front for the front eye bolt then I’ll work on the front bulkhead. So glad I’ll never ever have to look at the stringers again! The stringers were the most tedious time consuming part of the project. It’s all downhill from here on out.Click image for larger version.
ID:	483900Click image for larger version.
  9. Likes LakeFever, tnelsmn, Laseraddict liked this post
  10. #111
    May 2020
ID:	484252Click image for larger version.
ID:	484253Click image for larger version.
ID:	484254Gaining some ground today!
  11. Likes tnelsmn liked this post
  12. #112
    Jun 2018
    Floating around
    Home stretch now! Looking good
  13. #113
    May 2020
ID:	484317Click image for larger version.
ID:	484319Got my bulkhead framed in and a new bow block out of coosa in.ran out of epoxy resin again, more is on its way though.Click image for larger version.
ID:	484320 Oh boy, looks like my kid has this disease.
    Attached Thumbnails Attached Thumbnails 820AF506-2D8F-4538-A598-2E8E758657F8.jpg
  14. Likes LakeFever, tnelsmn liked this post
  15. #114
    May 2020
    Got the bulkhead and seat box tabbed in today, also glassed the front eye bolt in and tabbed in the corners of my rear seat.Click image for larger version.
ID:	485351Click image for larger version.
ID:	485352Click image for larger version.
ID:	485353Click image for larger version.
ID:	485354I have a layer of 1708 over my floor running from the bow all the way to about 2” behind the seat box, I obviously did this before I put the bulkhead and seat box down, I’ll continue with the 1708 over the floor as I work my way to the back of the boat. The seat box and bulk head lids are just screwed down for now so I could keep everything square while the glass hardens, once it cures I’ll pop off the lids and tab the insides of bulkhead and seat box and continue on.
  16. Likes tnelsmn, Laseraddict liked this post
  17. #115
    May 2020
    Today I tabbed in the inside of the seat box, the inside of the bulkhead and tabbed in the toe kick for my rear seat. Click image for larger version.
ID:	485394Click image for larger version.
ID:	485395After things harden I’ll drill drain holes in the seat box, bulkhead and toe kick until then I’m calling it a victory for the weekend.
  18. Likes LakeFever, tnelsmn liked this post
  19. #116
    May 2020
    Anybody have alternative cleaning chemicals other than acetone? Every time I get done working on the boat my eyelids swell up and it usually takes about 5 days to clear up. It’s either the acetone or the epoxy that’s doing it, I use a tyvek suit with a 3m respirator when sanding and vacuum everything up before in take the suit and respirator off. This weekend I tried something funny and put pieces of flexible medical tape over my eyelids before I started work on the boat and left it on the entire day ( both days) and took a shower as soon as I was done working. I figured I could use the extra protection and possibly rule out that the fiberglass dust was what is making my eyelids swell, well wake up Sunday morning and eyelids are all puffed up... now I’m thinking it’s either the acetone or epoxy, I use the acetone to clean all my tools and buckets after each batch of epoxy which is a lot of times in a 8hr work day, is there something other than acetone to use for this? Remember I’m using epoxy.
  20. #117
    Minneapolis MN
    Ever consider a full face respirator? I wore one of these when grinding all the gelcoat off. Uses the same cartridges as a half respirator.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
  21. #118
    May 2020
    Quote Originally Posted by tnelsmn View Post
    The one I have is just like that it totally seals my head off.
  22. #119
    Minneapolis MN
    Oh damn. Well I got nothing then. Hope you can find a solution!
  23. #120
    May 2020
    Next I’m gonna use a fan when doing the work, blow the fumes away from me...
  24. Likes tnelsmn, Laseraddict liked this post
  1. 1977 Ventura II Race Boat For Sale
    By JWTjr. in forum Hulls up to 20'
    Last Post: 09-30-2014, 04:59 PM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. How fast?1977 ventura II
    By busa198 in forum General Boating Discussion
    Last Post: 03-01-2010, 08:04 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Ventura set up ?s
    By zzzman in forum Props, Setup, and Rigging
    Last Post: 11-15-2006, 07:41 PM
