Page 7 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 91 to 105 of 250
  1. #91
    Transom, what's the history on the conversion from a tunnel hull to the design that we know now? I have never heard of this and am very curious. Thanks....
    It started life as the tunnel hull Panther but Howard realized a tunnel wasn't going to sell as well as a V-hull so they cut it up and he designed the V portion. If you look under the deck in the front of a Ventura you can still see the remains of the tunnels. The story may be on Hydrostream.org, I'll see if I can round up a link.
    May 2020
    I got the motor with two raker props, one is a 24pitch dialed in by DAH and the other one is a 23pitch ski prop. The motor came off a heavy 20+ foot Switzer craft.
  3. #93
    Quote Originally Posted by Jmr1974 View Post
    Pitch that small will be way too inadequate for the 235 on the Ventura.
    Here it is, from some old interviews Howard did.
    hydrostream.org/Drift'n/Driftn1.htm
    About half way down the page. The Panther looks just like a Ventura I.
    Collector Boats - HYDROSTREAMS
  5. Thanks LakeFever, Watercraft thanked for this post
    Likes XstreamVking, Laseraddict liked this post
  6. #95
    Very cool story, I did not know of this evolution. Love the drawn on a paper bag part....Thanks very much Transom stand.
    Jun 2018
    Floating around
    Very cool! Thanks x2
    Is the Vandal basically a mini Ventura?
  8. #97
    It is in my mind. Not sure if that was Howards intent, but it sure looks it.
  9. Thanks LakeFever thanked for this post
    Likes XstreamVking liked this post
  10. #98
    Without paper bags and cocktail napkins, some of the greatest triumphs of mankind never woulda happened
  11. Likes XstreamVking, LakeFever liked this post
  12. #99
    May 2020
    By the way your Ventura is an awesome looking boat, it’s what made me want to find one and restore it. That and they are a little more uncommon as far as hydrostream go. If I didn’t buy the one I’m restoring it was headed to the junk yard the owner told me, gone for good.
  13. Likes Laseraddict liked this post
  14. #100
    Thanks. But if you REALLY want to get set up right....you need to hire a bunny as a technical advisor. He taught me everything I know
  15. Likes tnelsmn liked this post
  16. #101
    May 2020
    Haha, maybe I’ll get myself a jackalope to ride shotgun...
  17. #102
    May 2020
    Gonna finish capping of my stringers today then work on the underside of my floor plywood. Should I use 1708 for the underside or csm? The top of the floor will be 1708.
  18. #103
    Underside of mine is just sealed with resin. If you wanna cover it, just csm, the plywood doesn't need additional strength.
    May 2020
  20. #105
    May 2020
ID:	483248Click image for larger version.
ID:	483249 Got the underside of my floor epoxied up with one layer of resin, gonna let it tack up and add another layer of resin. I opted to just do the epoxy on the underside and not add the csm, also added 2 cleats where the gas tank will be mounted. Also got my stringers all capped off and a drain plug block made out of 2 pieces of coosa epoxied together with csm in between, just need to shape the block and glass it in. So glad the stringers are finished, I’m sick of kneeling down in the boat at goofy angles. This is becoming fun now.
  21. Likes LakeFever, tnelsmn liked this post
  1. 1977 Ventura II Race Boat For Sale
    By JWTjr. in forum Hulls up to 20'
    Last Post: 09-30-2014, 04:59 PM
  2. Best workstand to build powerheads? Build? Buy?
    By Zoomba in forum Technical Discussion
    Last Post: 03-10-2014, 07:45 PM
  3. How fast?1977 ventura II
    By busa198 in forum General Boating Discussion
    Last Post: 03-01-2010, 08:04 PM
  4. Build better and Safer Build Union
    By SnakeBit in forum The Scream And Fly Lounge
    Last Post: 09-06-2008, 05:00 PM
  5. Ventura set up ?s
    By zzzman in forum Props, Setup, and Rigging
    Last Post: 11-15-2006, 07:41 PM
