Results 16 to 30 of 38
Thread: Octane booster
    MMT, it has to be fresh , sealed and kept out of the light, mix after dinner in the evening.
    Royal Purple Max Boost(Texas) and 10-15% Toluene total volume on 91 no alcohol gas and you have good fuel.
  2. #17
    Jun 2004
    Morgan City, LA
    Klotz Booster works great and good price. We been using it for years. Outboards and cars.
  3. #18
    Dec 2017
    sam rayburn lake...east texas
    Quote Originally Posted by CUDA View Post
    Is that cranking it with 12 or 24 volts
    12 v cranking
  4. #19
    Quote Originally Posted by ivlakeman View Post
    Tcatrett I'm running carbs with plastic floats does it melt them are gas lines I run this boat everyday when the weather gets good and I would like to try KLOTS gal not but 50 bucks said it lubricates cylinders that's a plus
    PDS Max-Boost
    https://royalpurple.wpengine.com/wp-...Boost-2019.pdf
  5. #20
    JAX. FLORIDA
    The best oxygenator/Octane boost was MTBE but is only available in Latin America countries due to spillage making groundwater taste bad. Second best is a toulene/Napthene combo that was used in Formula one cars.
    "Confidence" is that wonderful feeling you had right before you fully understood your true situation.- Unknown
    I don’t know what effect these men will have upon the enemy, but, by God, they terrify me.- Duke of Wellington
    “I am not afraid of an Army of lions lead by a sheep; I am afraid of sheep lead by a lion.” – Alexander the Great
    Whoever said the pen is mightier than the sword obviously never encountered automatic weapons.-Douglas MacArthur
    Allison GSE 300XS
  6. Likes FMP liked this post
  7. #21
    In a 6 gallon jug,. 5 1/2 gallons no alc 91 , 1/2 gallon toluene, good instructed amount RP Max MMT, 40:1 RP Two Stroke mix , never look back. Don't think 150psi cranking needs all that but if it's a barge workhorse on WOT all day.
  8. #22
    Dec 2017
    Quote Originally Posted by Tcatrett View Post
    Tcatrett ,....I'm running carbs with plastic floats does it melt them down are gas lines I run this boat everyday when the weather gets good and I would like to try KLOTS gal not but 50 bucks said it lubricates cylinders that's a plus
  9. #23
    Jun 2004
    Morgan City, LA
    There is 8 of us running it in boats out of our shop. no problems at all. 1 ounce per gal raises octane 2-1/2 numbers. claims you can raise up to 10 numbers max. We tested it in 2.5 mercs 2 ounces to gal at 180 compression with good results. I mix 3 oz to gal in my drag car. Lowers egts and runs lil harder. Do dot spill it on paint or gelcoat. It will stain.
  10. Likes rgsauger liked this post
  11. #24
    Dec 2017
    ok thanks I just ordered gallon I'm down on Sam Rayburn cant find any help on the old 2.5 but thanks to you folks on here its been fun putting a little more power in the old mercury did a lot of drag racing back in my days but being retired all that has stopped just fishing now but cant be normal just got to go a little faster but thanks for all the help u guys give me its been fun and keeps me going
  12. Likes rgsauger liked this post
  13. #25
    Mar 2015
    DFW
    using Klotz booster here as well, never had results even close to what the Klotz gives with any other product. Just be careful when using it, getting it on any paint or gel will almost instantly discolor that color. PreMixing it is the best way to go just for ease of getting it in the tank.
  14. Likes ivlakeman, josh7_78 liked this post
  15. #26
    Dec 2017
    Quote Originally Posted by Noah Burns View Post
    ok thanks for the info...... I got a gal headed my way some say they are mixing it in the mixing oil is that a good thing to do ?????
  16. #27
    Lake Coochiching, Ontario
    MTBE is so toxic that the manufacturer would not sell it to us when I worked on propane engines for a major car company. They said it was not safe for us to handle. Lead!
  17. Likes ivlakeman liked this post
  18. #28
    Mar 2015
    DFW
    I pre-mix it all together in a 5 gallon can for however much fuel I am going to run. Meaning, if I am going to put in a total of 25 gallons of fuel to my otherwise empty tank, I add ~100oz of oil, 25-50oz of Klotz (whatever is appropriate for the fuel I am mixing to) and fill the rest of the can with fuel to mix. Then add to the tank and fill the tank... easy peasy. I do it this way to eliminate the chance of getting the klotz on my deck as well as so I can control my OCD and keep a count on everything. Otherwise I start getting the sticky head and questioning rather I put everything in, put it in in the correct quantities etc...
  19. Likes ivlakeman liked this post
  20. #29
    Nov 2005
    https://boostane.com/octane-boosters...tane-boosters/
    This actually raises octane levels and does not separate over time. It also includes anti corrision addive against ethanol, cleaning agents and lubrication. Only "negative" thing I noticed is that it leaves a little orange color residue on the spark plugs.
  21. Likes engineermike, ivlakeman liked this post
  22. #30
    Orange is the MMT
  23. Likes JR IN JAX liked this post
  1. Octane Booster?
    By TraceF3 in forum General Boating Discussion
    Last Post: 05-10-2018, 06:23 AM
  2. octane booster
    By Big Johnson V8 in forum Technical Discussion
    Last Post: 11-21-2006, 04:41 PM
  3. Best octane booster?
    By 300Procraft in forum Technical Discussion
    Last Post: 03-31-2005, 10:13 AM
  4. Octane booster
    By Baja18 in forum Technical Discussion
    Last Post: 06-30-2003, 03:41 PM
  5. Octane Booster and bad gas
    By Liberator24 in forum General Boating Discussion
    Last Post: 03-18-2003, 10:59 PM
