Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 38
Thread: Octane booster
    Dec 2017
    sam rayburn lake...east texas
    Octane booster
    anyone running a octane booster with no troubles that's made for use in a 2.5 mercury carb motor if so what brand an where can u get it
    Jan 2015
    I have seen a bunch of people on here swear by Toluene. Not sure of the ratio or what not but you can search the threads to see what to do.
    Here are the two that came up on top. If this does not tell you what you need to know, you can search for more.
    https://www.screamandfly.com/showthr...hlight=toluene
    Dec 2017
    what about this ????
    DOMINATOR® Octane Boost
    Product code : AOBBE-EA
    5 Read 29 reviews
    Improves Performance in all Two- and Four-Stroke Gasoline-Fueled Engines
    Maximizes power and improves performance in all two-cycle and four-cycle gasoline engines. Increases octane up to 4 numbers. Reduces engine knock, improves ignition and engine response, helps fuel burn cleaner and inhibits corrosion. Recommended for off-road and racing use.
    Apr 2016
    Victoria bc canada
    I use ACES 2 stroke formula, great stuff with an excellent reputation to back it up, search it on here, lots of guys use it with amazing results, Jay Smith does a great right up on it.
    15.5 cobra 175 hp merc - sold
    18 tahiti tiger O/B 200 hp merc - sold
    19 STV euro - 2.5 merc DRAG
    Seebold F1 tunnel - 2.0 F1/champ
  5. Likes InjectorService liked this post
    Oct 2009
    Gonzales, La
    I’ve tested Boostane in 93 in a supercharged 2018 mustang, where the spark control strategy constantly looks for the knock limit. It definitely was very effective. The provided mixing chart appears to be pretty accurate.
    Dec 2017
    F
    uel Analyzer Tester Octane Number Gasoline Petrol Control ..... for checking octane
    Gothenburg, Sweden
    There is no magic to raising octane. Use what the refineries use, i.e. aromatics like toluene.
    If an octane booster works, it contains that kind of chemicals. You just pay more for the cool name.
    If it does not contain that kind of chemicals - a warning sign is that you only need a tiny amount - it is snake oil.
  9. Likes JR IN JAX liked this post
    Gothenburg, Sweden
    Quote Originally Posted by Brookbbb View Post
    ...but you cannot measure the effect in an octane testing machine.
    Draw your own conclusions.
    Dec 2017
    what is the mix ratio using racing gas in 93 octane pump gas and what octane racing gas I have 150 compassion and 93 pump gas is not working so how do i mix it for and old 2.5 mercury with carbs ??????????????? just not interested in a booster that eats up floats and gas lines
    Gothenburg, Sweden
    You can assume that the mix ratio is linear. So it depends on what octane rating the race gas has.
    At 150 pounds compression in a 2.5 liter Mercury, 93 octane should be close to what you need, unless you run extreme timing.
    From what I remember, we ran 98 RON = 93 (R+M)/2 in a 2.5 260 with 33cc heads and cold compression in the high 140s according to the (cheap) gauge.<object id="__symantecPKIClientMessenger" data-supports-flavor-configuration="true" data-extension-version="1.0.1" style="display: none;"></object>__PRESENT
    Dec 2017
    I was running 145 pounds with no problem made a piston change now its at 150 and now I have a 93 pump gas problem but I may just go back to stock head gasket should get it back to 145 I just got 3 hrs on this motor just hate to have to pull the heads back off but maybe the safest thing to do
  14. #12
    Aces and VP. I've used both in 185 PSI motors and they work fine.
  15. Likes Dave Strong, mrcrsr liked this post
  16. #13
    PARADISE /Naples
    Quote Originally Posted by Markus View Post
    Is that cranking it with 12 or 24 volts
  17. #14
    Lots of mix ratio charts and DIY octane booster formula's on line. Google is your friend.
  18. #15
    Oct 2009
    Gonzales, La
    If you get bored, 4 guys with supercharged coyotes tested aces iv and the “p” version and reported. Supercharged coyotes are 11-12/1 compression so when boosted to 10-14 psi need all the octane they can get. The coyote knock control system is extremely sensitive and incorporates per-cylinder knock retard and advance, so is VERY good at sensing changes in octane. The bottom line is that all versions of aces did zero to increase octane in 4 different cars. Boostane and octanium did have measurable improvements. The active ingredient is MMT.
    https://www.mustang6g.com/forums/thr...nhancer.80623/
  19. Likes FMP liked this post
  1. Octane Booster?
    By TraceF3 in forum General Boating Discussion
    Last Post: 05-10-2018, 06:23 AM
  2. octane booster
    By Big Johnson V8 in forum Technical Discussion
    Last Post: 11-21-2006, 04:41 PM
  3. Best octane booster?
    By 300Procraft in forum Technical Discussion
    Last Post: 03-31-2005, 10:13 AM
  4. Octane booster
    By Baja18 in forum Technical Discussion
    Last Post: 06-30-2003, 03:41 PM
  5. Octane Booster and bad gas
    By Liberator24 in forum General Boating Discussion
    Last Post: 03-18-2003, 10:59 PM
